Tym 353
   / Tym 353 #1
williamsummerlin
New registration to forum, looking for input on a current problem. My pto spontaneously turns on when the dash switches are turned off. This is a dangerous problem. Has anyone else had this to happen? I also have a problem with the Gage's going to zero occasionally. Any suggestions😩😩😩😩
   / Tym 353 #2
:welcome:
To TBN William. Where are you located?
   / Tym 353 #4
Hi William, and welcome to the forum :welcome:
I have moved your thread to the TYM section so that you can get more answers.
   / Tym 353 #5
Does it have electronic PTO with a switch and relay? If so check relay. When it comes on does it happen with a load on it or just wen nothing is hooked up?
   / Tym 353
I believe it does, it has two switches, one that operates the pto on automatic and or manual. A second push on off switch that turns it on and off. Do you think it is a wire going to ground or what. Thanks for your interest.
   / Tym 353 #7
It does sound more like a short or intermittent ground issue with the wiring than an issue with the PTO.
   / Tym 353 #8
Hi, did you ever figure anything out with this issue? I'm having the same luck
   / Tym 353
Don’t really know if my latest issue is related to this, but recently had gloplug issue which turned out to be a short where red glowplug wire was shorting out just where the wiring harness went down behind the radiator and shorted on a sharp corner of the battery plate . May have been an intermittent grounding that ended up being a short to ground that blew my 60 amp fuse.
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A51572)
2008 Hino 268...
2014 Kia Sedona Van (A50324)
2014 Kia Sedona...
EZ-GO D499 Electric Golf Cart (A51694)
EZ-GO D499...
2018 Ford Transit 250 Cargo Van (A51692)
2018 Ford Transit...
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
