Tym 27hp Tractor losing Hydraulic power
   / Tym 27hp Tractor losing Hydraulic power #1
dayjd1
Hollis Center, Maine
TYM273
For the last couple weeks I have noticed my bucket coming up slower and with my forks attached to the bucket it tends to come down when the tractor is off. Recently even if the tractor is running it still wants to lower itself. It does not raise as high as it use to and it lift capacity is much less than it use to be. The hudraulic pressure oil window at the rear of the tractor shows the oil is maybe half to 5/8 full when running or not.
Anyone have any idea what the tractor problem could be? Thanks for your help, Bill
   / Tym 27hp Tractor losing Hydraulic power #2
Leaking seal internally on the cylinders, or a leaking valve.
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A52576)
2015 KENWORTH T370...
Industrial Air Contractor Air Compressor (A51573)
Industrial Air...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51691)
2020 Polaris...
