TYM 273HST Wont move
/ TYM 273HST Wont move #1
Amhobby
Sealy, tx
TYM 273HST
I have a 2006 TYM 273HST with 400 pretty easy hours on it. A couple days ago I was smoothing out a small high spot in my yard a with my box blade. When I went from forward to reverse it made a popping sound followed by a noise that sounds like a heavy rattling grinding sound from underneath. The noise changes somewhat with throttle. Everything works except the PTO and it wont move in 2WD or 4WD. Any ideas will be greatly appreciated. I can't find anyone locally that can look at it before 2-4 weeks
/ TYM 273HST Wont move #2
Check your drive shafts front and back ,sound like the coupling my have a broken spring pin . easy to fix
/ TYM 273HST Wont move #3
Broken drive shaft. They have a redesigned one now. Cost around $250 When I replaced mine.
/ TYM 273HST Wont move #4
went down that road, the upgraded replacement won't last much longer. look for a drive line specialist that will build you one made with automobile drive shaft u joints.save yourself some aggravation and money.
