TYM 233 PTO doesnt work. Oil level very high
   / TYM 233 PTO doesnt work. Oil level very high #1
Bob Nelson
Bronze Member
Oakland, MI
Branson 2400h, New Holland TC33d, Ford 1720, Kubota BX2350d
I bought a 2009 TYM 233 and the PTO in not working. When I bought it, the owner had a 5' brush hog on it to show me it worked and it did!. But now at home, it does not work. The button illuminates but the lever that you push to engage is like loose, just can move back and forth real easily like something is not connected inside.
I have also noticed that the fluid level is higher than when I bought it but I have not added any oil. The loader is fine and the hydrostat trans works good as does the 4wd.
Any ideas??
   / TYM 233 PTO doesnt work. Oil level very high #2
Did you get resolution to this issue?
   / TYM 233 PTO doesnt work. Oil level very high #3
Check the remote lever under the seat and make sure it in the middle not to the left or right.
Lot of 2 Caterpillar Loader Tires (A51691)
Lot of 2...
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2010 Honda CR-V SUV (A51694)
2010 Honda CR-V...
JOHN DEERE LOT NUMBER 123 (A53084)
JOHN DEERE LOT...
2015 Mack GU813 Mixer Concrete Truck, VIN # 1M2AX13C0FM028499 (A51572)
2015 Mack GU813...
