TYM 233 Gauges and Tach going out
   / TYM 233 Gauges and Tach going out #1
kb12610
TYM 233
It just recently started with the gauges and tach not working. Sometimes they're fine others dead. It's from start up, they either work or they don't for as long as the tractor is running. Was thinking maybe a ground problem. Tractor is about 12 years old.
   / TYM 233 Gauges and Tach going out #2
I'd pull the steering wheel and gain access to the wiring harness and relays. I probably get one mouse nest per year in there and between urine and chewing all kinds of wiring issues can ensue. Unfortunately I've never been able to find a readable wiring diagram, so you might have to hunt and peck to figure out what the culprit is, but it definitely sounds like a wiring issue, and possibly a loose ground as you mentioned.
   / TYM 233 Gauges and Tach going out #3
If you can access the electrical connector for the instruments try disconnecting and reconnecting it to check for improvement. Determine how your instruments are grounded and ensure the connection is secut.
Yeah I know, I just hate pulling the steering wheel every time I need in there.
   / TYM 233 Gauges and Tach going out #5
Don't I know it. . . At least you don't need a steer wheel puller to get it off. :)
I have the wiring diagram from the owners manual. Seems to be fairly accurate, majority of the colors even match. I take a picture with my phone of the section I need and zoom in on it. Might try it if you haven't.
   / TYM 233 Gauges and Tach going out #7
I have the version from manual as well, but it's way too low resolution to interpret pin-outs. The colored wires kinda help, but it's not ideal. I'm assuming the shop version is a six page fold-out that was shrunk to 1 page for the user manual.View attachment T273_WiringDiagram.pdf
I have the version from manual as well, but it's way too low resolution to interpret pin-outs. The colored wires kinda help, but it's not ideal. I'm assuming the shop version is a six page fold-out that was shrunk to 1 page for the user manual.View attachment 663504
Is yours just the digital copy, I looked and I have that one too but the one in my owners manual is a long page fold out and although small magnifies very well.
   / TYM 233 Gauges and Tach going out #9
I only have a digital copy of the owners manual. Adequate for most repairs, but not for the wiring diagram. Would you possibly be willing to make available a higher resolution photo/scan of the hard copy of the wiring diagram? I posted a thread about this and like 100 folks viewed the post, but no one responded. I'm willing to bet that a lot of us would benefit from the high res diagram.
If I can figure out a way, I'll work on it. By the way does yours by any chance have the rear hydraulics. Would like to see the arrangement of how its plumbed. Dealer had a NOS kit but wanted $880 for it.
SNOW DOG SALT BOX TRUCK MOUNT SPREADER (A52577)
SNOW DOG SALT BOX...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
STORAGE FEES (A52577)
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
