TYM 233/273 Main Hydraulic Pump Specs, Has anyone had one off or Upgraded
   / TYM 233/273 Main Hydraulic Pump Specs, Has anyone had one off or Upgraded #1
kb12610
TYM 233
Looking for info on the main Hydraulic pump on a 233/273. Mainly the shaft style. The pump is the Joyang 7cc-L. I have Joyang specs and it lists 3 shaft styles available. Specs say keyed, 12 spline, and a tang style, I'm trying to determine what style of shaft it uses without pulling the pump. When warmer weather arrives I'll cobble together a pressure gauge to check system pressure. But at 11 years old I think its a little weak. If anyone has replaced or upgraded there pump would like to hear what you've replaced it with. External dimensions I can pull without much problem.
   / TYM 233/273 Main Hydraulic Pump Specs, Has anyone had one off or Upgraded #2
Checking wear on a pump with a gauge doesn't tell you anything. A worn gear pump can get pressure like a new one. If your pressure is low, you could as well have a faulty pressure relief valve.
Testing the output volume of the pump tells you about wear more accurately. This can't be done with a gauge.
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
2012 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
500BBL WHEELED FRAC TANK (A52472)
500BBL WHEELED...
1995 BEALL TRAILER FUEL TRANSPORT PUP TRAILER (A52472)
1995 BEALL TRAILER...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
