• Thank you for participating in the Summit Tractors Community. Per special arrangement with the TBN team, Summit Tractors will regularly monitor and contribute to this forum to help ensure that the community has direct access to Summit. You can ask and find answers to a range of topics directly from Summit and from other TBN users, including; Where to Buy, Future Retailers and Locations, Financing, Compatible Equipment, Tractor Operating, Equipment Specifications, Parts & Service Support, Warranty and anything else that may assist those in the market for a new tractor. If you cannot find the answer to a specific question on this forum, please feel free to contact Summit Tractors Directly or through a Private Message to Summit Tractors Support via TBN.
Ad top of page
TX25 wheel spacers
   / TX25 wheel spacers #1
ford601
Solis h24+ and 1960 ford 601
Ive provided measurements to bro-tek and they're in the process of making rear wheel spacers for the tx25/h24. The front wheels are 5x4.5 lug pattern with a 3" hub opening and 87-06 jeep wrangler spacers work. The fronts require lug bolts, not nuts. The thread for the lug bolts is 12x1.25.
   / TX25 wheel spacers #3
I assume the rears have a 5x4.5 lug pattern as well. Is the rear the same hub opening? I have just ordered a TX25 to be delivered next month and I would like to order/add spacers to the rear.
   / TX25 wheel spacers #4
Hello,
We do not recommend adding wheel spacers because of the added strain they put on the unit. Thus, we will not warranty any failure caused by wheel spacers, so please keep that in mind!
Thank you,
The Summit Support Team
   / TX25 wheel spacers #5
OOh, good to know. Ill scratch that idea then.
2009 IC Corporation PB105 School Bus (A46683)
2009 IC...
Feed Bunk (A49339)
Feed Bunk (A49339)
2008 BMW 535xi AWD Sedan (A46684)
2008 BMW 535xi AWD...
2008 Ram 1500 4x4 Crew Cab Pickup Truck (A46684)
2008 Ram 1500 4x4...
2016 Volkswagen Tiguan SUV (A46684)
2016 Volkswagen...
2014 UTILITY 53X102 DRY VAN TRAILER (A45678)
2014 UTILITY...
Ad bottom of page
