Two way log splitter + grinder
   / Two way log splitter + grinder #2
that is good only if the wood isnt stringy .
   / Two way log splitter + grinder #5
I think someone was stoned out of his gourd when he designed that log splitter!!!!
   / Two way log splitter + grinder #6
Woodsplitter. . .just because you can doesn't mean you should.:rolleyes:
   / Two way log splitter + grinder #7
I love the stump grinder!
   / Two way log splitter + grinder #9
Yes there is a lot of torque in that shaft and grinder. Enough to pick the left rear of that tractor off the ground!!
Mike
   / Two way log splitter + grinder #10
That's about the most inefficient log splitter I have ever seen. I am sure I can out split it by hand.
Andy
NEVER USED FECON 74in Deck Mulcher FDM74 (A51039)
NEVER USED FECON...
2016 Ford Taurus SE Sedan (A48082)
2016 Ford Taurus...
2012 Ford F-350 Mechanics Service Truck (A48081)
2012 Ford F-350...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
2015 GMC Sierra 1500 SLE 4WD Pickup Truck (A50860)
2015 GMC Sierra...
2025 K0520 UNUSED Welded Wire Mesh Roll (A50860)
2025 K0520 UNUSED...
