two stroke oil or no oil in crankcase
   / two stroke oil or no oil in crankcase #1
woodcrosscut
john deere 3320
Hello All....I have a Dolmar cut off saw model 7314. The saw has become impossible to start lately and so I checked the compression and there is very little. I have purchased parts to rebuild the saw a cyl/piston kit and gaskets. My problem is that I found oil in the crankcase it is a very small crankcase but the shaft is half covered in the oil. I have been told that in a two cycle engine there is no oil in the crankcase the engine is lubed via the gas oil mix. I don't see or undrestand how the the crank shaft is lubed with the gas / oil mix going direct to the combustion chamber. I have done a lot of rebuilding and repairs on four stroke but none on two stroke.Does anyone know where I can get a repair manual for this unit. Any help and or advise would be very welcomed.
   / two stroke oil or no oil in crankcase #2
The oil/petrol mix passes through the crankcase lubing the big end etc on its way to the cylinder.:)
   / two stroke oil or no oil in crankcase #3
There is a chain/ cutoff saw online dealer in London Ontario ( Cutters Choice ) .I believe there is a US site ( Cutters Choice.com ). They have lots of parts and I have had good service from them.
Craig Clayton
2018 John Deere 9470R Tractor (A53342)
2018 John Deere...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2007 BobCat S175 Skid Steer (A52384)
2007 BobCat S175...
2025 Star EV Capella Electric Low speed Golf Cart (A51694)
2025 Star EV...
2015 Ford F-250 Knapheide Service Truck (A51692)
2015 Ford F-250...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
