Two stroke diesel??
   / Two stroke diesel?? #1
northcreek2624
Lake View,N.Y.(WNY)
KIOTI DK40(2002)) Jacobsen 628D AWD Turfcat
Seems that I saw/heard of a two stroke diesel engine but,can't seem to remember the details.
Is there such an animal? and what would the application be?
Just wondering....Mike
   / Two stroke diesel?? #2
Yes Mike,
There are 2 stroke diesels.
The old Detroit diesel engines were 2 stroke.,used in large trucks,bus,high lifts,rollers,etc.
Detroit has since gone to 4 stroke diesel engines.
   / Two stroke diesel?? #3
Yep--there is such an animal!! The old GMC's were all 2-strokers. These weren't quite like 2'st. gas engines in that they had a pressure lubrication system, and oil in the crankcase just like a 4-st. But for the induction system they then used a supercharger to pressureize the intake. If you remember not too many years ago all the Grayhounds and Trailways busses had a noisy smoking gutless engine called a Detroit?? Detroit is what the old GMC became. The application were generally OTR trucks, truck mounted cranes, oilfield, and industrial uses. There were farmers that took the old LA model Case tractors(gas burner@ 50 hp.) and put in 3 cyl
GM's @ about 95 hp. Then about a year later they would all have to buy hearing-aids!!!! There were also some GM's put in some Oliver tractors- Don't know if this was factory or homespun, though.
   / Two stroke diesel?? #4
You've been around lots of them. In vehicular applications especially they had a sound unlike other diesels. Imagine the sound of the offspring of a diesel bred to a vacuum cleaner and you'll be close. They're also found in a lot of stationary applications like saw mills and water pumps.
If I recall correctly they also had a reputation for oil leaks. If you want one, they're common as dirt. Before Penske bought the company they were built by GM.
   / Two stroke diesel?? #5
Sure an beggorah, lad, there be two stroke diesels. Back in the 50's while just a tot a friend of mine had a 2 stroke diesel model aircraft engine (not that rare). Funny thing, "regular" model aircraft engines are two stroke with glow plugs (sounds almost diesel, huh?) with some 4 stroke engines with spark plugs in the large economy sizes. The itsy bitsy diesel engines for flying models had variable compression. Where yo would expect to find a spark or glow plug there was a wingnut affair that you screwed in to raise compression and out to lower it. Lots of ether in the model diesel fuel as I recall. Buggers to start in the winter time, well heck, all the time but even worse in the winter.
There were several marine (vessel propulsion) applications of 2 stroke diesels. Little two stroke diesel engines were used in some foreign made powered bikes (Moped like things). There was a 2 stroke diesel imported into the us in the mid to late 50's (if memory serves) for retrofitting to a regular bicycle. Powered the rear wheel with a friction coupled rubber roller. No tranny, no clutch. Pedal to start. Braking to a stop killed the engine. Could disengage the rubber roller and treat as reqular bike. You pedal to start and to accelerate and to climb hills. It was not very powerful.
I think there were some diesel submarines with two stroke engines too.
Patrick
   / Two stroke diesel?? #6
Here's a good article on deisels in boats. It explains the differences between the 2 stroke Detroit and the 4 strokers.
I operated a Detroit Deisel 6-71 in a ground power unit at the local airport for years. Man, when you put the power on, that thing would blow your ears off! The 6-71 is an awsome engine that will last forever with a little care.
<A target="_blank" HREF=http://www.yachtsurvey.com/comparing_diesel_types.htm>http://www.yachtsurvey.com/comparing_diesel_types.htm</A>
   / Two stroke diesel?? #7
The diesel sub I toured had opposed piston Fairbanks-Morse diesels in it. There are some weird diesel engines out there.
   / Two stroke diesel?? #10
I beleive they were refered to as " Screaming Jimmy's "
My previous place of employment had natural gas Cooper Bessemer two cycle gas compressors. These things were at least 50 years old and had esentially ran 24 hours a day since new. They were a V10 design. Had a catwalk along each cylinder bank. The commpressor heads were an integral part of the engine. Max RPM was 300. They were air started and if backfired made a rather loud noise that dew the attention of a nearby town.
Egon
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2020 FREIGHTLINER...
Hose Reel (A55787)
Hose Reel (A55787)
202482 (A54757)
202482 (A54757)
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2019 Ford F-150...
2025 FUTURE X-DM43 SKID STEER DISC MULCHER (A58214)
2025 FUTURE X-DM43...
2013 Case 580 Super N 4x4 Extendahoe Loader Backhoe (A55973)
2013 Case 580...
