Two Stage Clutch Problem?
   / Two Stage Clutch Problem? #1
ford540a
Massachusetts
Ford 540A, Cletrac Crawler, McCormick Deering 10-20
I have a 1981 Ford 540A that I recently purchased. I believe it has a two stage clutch. When the PTO is engaged and I need to shift, I have to press the clutch all the way down to shift which also disengages the PTO. This tractor has been sitting for at least 8 years. Is this a problem? Does this tractor even have a two stage clutch? Also could I cause further problems using the tractor like this?
   / Two Stage Clutch Problem? #2
Pushing the pedal of a 2-stage clutch won't really hurt anything. However, it also depends on the implement being used. A mower or rotary cutter would lose a some RPM, but as long as you shift fairly fast, that won't really hurt anything (I had to do it with an old Deere 670). Something like a tiller may be a different story though. I don't have a tiller, but I would raise the tiller out of the ground during any shifting.
Hopefully, some othe Ford owners can provide better info then I did.
Here is a link to some more info, but it doesn't adress the 2-stage clutch specifically:
TractorData.com Ford 540A tractor information
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
2019 JOHN DEERE GATOR XUV855M S4 UTV (A51247)
2019 JOHN DEERE...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
WHYNTER ARC-102CS PORTABLE AIR CONDITIONER (A51248)
WHYNTER ARC-102CS...
44in Tooth Excavator Bucket (A51691)
44in Tooth...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
