Rotary Cutter Two Spindle Rotary Cutters (6 to 7 foot width non-offset) to Reduce Length
   / Two Spindle Rotary Cutters (6 to 7 foot width non-offset) to Reduce Length #1
Spanky100
NE Texas, NE Tennessee, and SE MI and SW OH
Current Kioti CK27HST and Cub Cadet 1810. Previous NH1510 Hydro, AC D14, Oliver 1355?, and JD 314 Lawn Tractor
I am looking for a 6 to 7 foot wide light duty Rotary Cutter. With a 6 to 7 foot single spindle rotary cutter the length from the 3 point pins to the tail wheel is longer then I would like to maneuver around. I see some offerings for two spindle rotary cutters in the heavy duty designs but not in the light duty designs.
Are two spindle non-offset light duty rotary cutters available in widths from 6 to 7 foot?
Wayne
   / Two Spindle Rotary Cutters (6 to 7 foot width non-offset) to Reduce Length #2
The Bush Hog SQ84T is the only two spindle cutter I know of. It's rated for up to 1-1/2" diameter brush, which makes it a medium light duty cutter in my mind.
If by "light duty" you mean "cheap", I don't think they exist. Keep in mind that on a dual spindle you're paying for an extra gearbox, driveshaft, blade carrier and blades.
I've never seen a 2 spindle 6 foot cutter. Even 6 foot finish mowers have 3 spindles.
   / Two Spindle Rotary Cutters (6 to 7 foot width non-offset) to Reduce Length #3
Did not know Bush hog made a two spindle cutter that was 7'. Learned something new today, I thought all of the twin spindle brush mowers started at 8'.
   / Two Spindle Rotary Cutters (6 to 7 foot width non-offset) to Reduce Length #4
Woods has 80" cutters (with and without offset) with twin spindles -- Product Details
Steve
Thanks for the information. The Bush Hog SQ84T is close to what I would like if it did not have the offset. The Woods D80 looks impressive at 1400 pounds. I would likie to stay below 1000 pounds Local dealer that sells both brands did not have either one in stock. Said he had order one SQ84T in the spring and it was sold by Memorial Day. Said they would likely order another one next spring and could order one anytime if I was going to purchase it. Likely due to the added cost over the single spindle machines they are not in high demand.
Wayne.
UNUSED JCT SKID STEER QUICK ATTACH 84" DOZER BLADE (A51244)
UNUSED JCT SKID...
2015 FREIGHTLINER CASCADIA DAYCAB (A52472)
2015 FREIGHTLINER...
(3) UNUSED FUTURE JUMPER CABLES (A51243)
(3) UNUSED FUTURE...
QUICK ATTACH 48" DUMPSTER FORKS (A51243)
QUICK ATTACH 48"...
Wolverine Mini Skid Steer Stump Grapple (A50515)
Wolverine Mini...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
