Two speed PTO on JD5x03s?
   / Two speed PTO on JD5x03s? #1
Bob_Young
Veteran Member
North of the Fingerlakes - NY
Ford 4000; Ford 2000(both 3cyl.);JD40; 2004 Kubota L4300; 2006 Kubota B7610; new 2007 Kubota MX5000
Looked at a couple of the 5x03s at a dealer recently. Both had their tachs marked in two places for PTO operation:
-1700 RPM was marked 'E-PTO' as I recall
-2400 RPM was marked 'PTO'
Didn't know E-PTO was available on the x03 models. Is it an option?
Looked at the control layout for quite some time trying to figure out how you would select one or the other. Couldn't identify anything that would do the job. Is this for real or do they just use this same tach on the more expensive tractors? JD site made no mention of Econo-PTO on these models.
   / Two speed PTO on JD5x03s? #2
I have a 5203 and noticed the indicator on the dash but not found a way to engage.
   / Two speed PTO on JD5x03s? #3
I think you have to move all the way up to the 5603 with cab to get the E-PTO.
AKfish
   / Two speed PTO on JD5x03s? #4
On my 5525 with ePTO there is a n additional lever neat the PTO engagement lever. The PTO runs at the same speed (540 RPM), but the engine runs at a lower RPM and it still puts out 540RPM on the PTO.
Some tractors do have different PTO RPMs: 540 rpm and 1000 rpm. Typically you pull the shaft out and turn it around to change between the 2 speeds.
D.
Ddivinia,
Yeah, that's what I was trying to say....540 RPM in either mode, but a lower engine RPM to get 540 in the economy mode. I'm aware of the 1000RPM PTOs and these tractors definitely didn't have that.
Sounds like the lower RPM mark on the tach is just a teaser for now. Too bad, it would be a nice feature. Wish I could justify/afford a 5x25.
Bob
   / Two speed PTO on JD5x03s? #6
Yeah, I think we just have the same tachs. Here's what I found on Deere's site regarding 540/540E:
Base Equipment On : 5325N, 5425N, 5525N, 5603
Optional Equipment On : 5225, 5325, 5425, 5525, 5525 Hi-Crop
   / Two speed PTO on JD5x03s? #7
I think 540E is one of the Premium tractor features, so you have to jump up to the series models to get it. They probably share the same instrument cluster. Limiting features/options is how JD (or anyone else) can keep prices low on the value tractors.
   / Two speed PTO on JD5x03s? #8
My 5525 cab has it if anybody needs a pic.
D.
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
Danuser 3 pt Post Hole Digger (A50515)
Danuser 3 pt Post...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Online Buyers Premium (A47384)
Online Buyers...
New Holland B95 Backhoe (A50490)
New Holland B95...
