Two new Stihls in last two months
   / Two new Stihls in last two months #1
BloomingtonMike
Platinum Member
John Deere 3320
This is the year for Stihl for me I guess. Started out with a chainsaw. I have spent some time on arboristsite.com and did my research on smaller mid size saws. I settled on the MS260 Pro with a 20" and 16" bar (trying both semichisel and full chisel chains). Outstanding saw if anyone is looking in this size. Pricey but weighs less than the MS290 Farm Boss and starts MUCH easier (hard the FarmBoss for the 7 day trial period and returned it for the MS260 Pro).
NExt up was a trimmer/brushcutter. For the money the FS250 was my solution. Picked it up this morning with 3 different metal blades (chisel circular saw, diamond shaped grass, and circular brush blade) and the line trimmer head. I chose the bike handle version. All I can say is WOW! This thing is down right fun! I like it alot. USed it for 5 hours today alone. It is a beast. With it I will be able to reclaim the side of my pond.
My plan is to clear up the pond sides and then get in and take out some of the trees. I am loosing some water due to teh root system in my clay.
Anyway really really nice Orange tools from a Green tractor guy.
I think I am going to make a nice carrying platform for brushcutter and saw he cary all to use the tractor to transport them.
   / Two new Stihls in last two months #2
I love stihl as well. I have a BR-400 blower and an FS-74 weed eater. Both I have had for 14 years with no trouble, they are stihl as good as the day I got em. I got a farm boss chain saw recently and an HL-75-K shrub trimmer. Stihl is money well spent.
   / Two new Stihls in last two months #3
I've had my 025 chain saw for 13 years and my FS85 trimmer for the last 6 years. I've never had a problem with either.
Solo
   / Two new Stihls in last two months #5
I bought a new 440 mag chainsaw it sucks,went through 2 bars and chains.While hears the storygot the saw used the saw wore out bar took back to dealer said i ran it out oil I said no i didint so bought new bar and chains,used saw went though bar and chain very short time 4 6 full cord clean wood went back he looked all over said ran out oil no i didnt now what that saw is junk
   / Two new Stihls in last two months #6
The oil jets get stopped up and have to be cleaned in order for the bar oil to flow, I have my screw set wide open to help keep the pulp flushed out. The only thing I can figure is running out of bar oil or not keeping the jets clean. Most of the time when a high quality unit gives problems its the operator not being attentive. You can over heat the chain and dull it in no time when no bar oil is flowing. Keeping the chain adjusted throughout the time using it is important and when you are through using the saw you should loosten the chain (assuming you kept it properly adjusted) so when it cools and shrinks it want warp the power head. perhaps you will have better luck with a $99.00 special.
   / Two new Stihls in last two months #7
i cut with a 066 mag. on the underside of the saw there is a oiler screw turn it for maximum flow. maybe this will help you out.
2 pair -st205/75r15 radial trailer tires (A53421)
2 pair...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
