two double acting cylinders for plow angling
   / two double acting cylinders for plow angling #1
hazmat
Elite Member
West Newbury, MA & Harrison, ME
Kubota L5460HSTC
Getting ready to place my order, Realized that the cylinders I designed to are double acting.
I think this is a blessing in disgiuse: Can you say brush grapple for front bucket!
Question is, should I convert them to single acting for the plow (via breather inserted in unused port) or plumb them up such that the left is pushing while the right is pulling & vice versa? Or simply just buy one?
I'm thinking that two cylinders will double my factor of safety regarding the lateral loading, but haven't actually done the calculation & don't have time to right now.
Need help fast, want to place order before 3pm, so it ships today.
   / two double acting cylinders for plow angling #2
I would use one cylinder, much simpler
hosing.
Remember KISS
   / two double acting cylinders for plow angling #3
If you have it designed for the double acting, by all means use them. It will be much stronger with a cyl on both sides to take the force of pushing.
Hmm, 1 for two against (Hoeman & my wallet).
I think I'll go for one for now. I can always add another.
   / two double acting cylinders for plow angling #5
Use one double acting, but size the cylinder according to the pull side force ((bore area - shaft area) x psi)...
   / two double acting cylinders for plow angling #6
i used single, double action piston on my Cheap Snow Plow, see power trac. Works great, same speed to both side. good luck
   / two double acting cylinders for plow angling #7
regular angling plow assy has 2 cyls..1 push,1 pull...change angle and they reverse....Sid
   / two double acting cylinders for plow angling #8
They both push only since it is a single acting
system.
Opposite cylinder just vents oil back to tank.
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
2015 FONTAINE TRAILER CO. 53 STEP DECK SPREAD AXLE (A50854)
2015 FONTAINE...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2016 Ford F-150...
2016 Ford F-150...
2009 Ford F-150 Pickup Truck (A48081)
2009 Ford F-150...
