Two Battery Break Away Questions
   / Two Battery Break Away Questions #1
TxDoc
Wamba, TX
Kubota ZG227, wanting BX25D
1-I have two trailers to add this to. I am using the Tekonsha 50-85-313 Push To Test Breakaway Kit with Premium Charger on both. I want to keep them inside the frame edges. The box, plastic, can mount with four screws, but I am leaning toward simply taking some 1-1/4" flat steel and making two "L"s that will cradle the battery box and mount right through the boxes' existing holes and through the frame. I don't want the plastic box to crack due to vibrations and lose the whole box. I just want to give it a little more support. And, to use some carriage bolts and red Loctite to make it a little harder to steal. Has anyone done just a basic addition like this?
2- This unit has a charger, inside the box, and charges when hooked to the truck. I will have an outlet about ten feet from both trailers to hook up a Battery Tender 800 Waterproof 12V Battery Charger, mounted to the frame. I have been using these on my ATVs and RUVs, ZTR mowers and garaged vehicles without any problem. They seem to resist water and vibration very well. This way, if I don't use the trailer(s) for a while, the batteries will be fully charged as they are hooked up. Same question, has anyone done this, too?
Thanks for the time and the help...and any suggestions or experienced advice.
   / Two Battery Break Away Questions #2
I don't see any problems with either.
Chris
Kawasaki NR (A50324)
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
JLG 1930ES ELECTRIC SCISSOR MAN LIFT (A51246)
JLG 1930ES...
UNUSED FUTURE HYD HEDGE TRIMMER (A51248)
UNUSED FUTURE HYD...
