TVO
   / TVO #1
deereman63
deere 2210
Was TVO (tractor vaporising oil) ever used in the United States. I remember my uncle using it in the UK but is no longer available. Any idea what the ratio of parrafin(kerosine) to petrol ( gas) was used. The tractor had two fuel systems. You would start up with gas and was the engine was warm enough you would switch over to this TVO.
   / TVO #3
I believe that what you refer to is the old diesel engines that had a pony motor on them that ran on gasoline. When the pony motor got the diesel spinning fast enough to get ignition, then you turned off the pony motor. I believe that by the mid 1960's these engines were no longer used.
   / TVO #5
We had a couple old WD-9 Internationals and a Farmall MD that started on gas then switched to diesel. These didn't have pony motors.
   / TVO
these machines only had one engine
Harrell 3605 (A50123)
1985 Ford Ltl9000 Tender Truck (A55301)
1985 Ford Ltl9000...
2020 BOBCAT T76 R SERIES SKID STEER (A52705)
2020 BOBCAT T76 R...
1996 JCB 506B Telehandler (A55218)
1996 JCB 506B...
2016 Hitachi XZ300LC-6 (A47477)
2016 Hitachi...
2014 10ft T/A Dump Trailer (A51691)
2014 10ft T/A Dump...
