Turning up the fuel on a diesel turbo charged tractor New Holland TL-90
   / Turning up the fuel on a diesel turbo charged tractor New Holland TL-90 #1
EverythingAttachments
Elite Member
Newton NC
Which One do you want to know about?
We add some serious horsepower to a New Holland TL-90 tractor quickly and for free.
Here's the uncut, non rehearsed video:
   / Turning up the fuel on a diesel turbo charged tractor New Holland TL-90 #2
Sweet!
   / Turning up the fuel on a diesel turbo charged tractor New Holland TL-90 #3
Very cool! That just points out one of the reasons why tractors can run for so long without problems...they're built to handle a lot more power than we're using putting through them.
   / Turning up the fuel on a diesel turbo charged tractor New Holland TL-90 #4
All I need is a dyno. I am inspired.
   / Turning up the fuel on a diesel turbo charged tractor New Holland TL-90 #5
Man, I am surprised at how much they got out of that motor. What? 48 percent more?
   / Turning up the fuel on a diesel turbo charged tractor New Holland TL-90 #6
   / Turning up the fuel on a diesel turbo charged tractor New Holland TL-90 #7
I wish we could see a clear shot of the nut they are actually turning instead of the back of the mechanics head or shoulder. But still a great video that shows us what's possible if you know what your doing.
I'm going to leave mine alone until at least the last payments made. :chicken::chicken:
   / Turning up the fuel on a diesel turbo charged tractor New Holland TL-90 #8
Honestly if your pump is similar enough to theirs it is pretty evident what they're going after. There are also lots of diagrams of the various pumps out there. Get the model/part number off your pump and look it up for better images of the pump. The pump on that NewHolland looked very much like the typical Bosch VE series pumps used on many diesels.
   / Turning up the fuel on a diesel turbo charged tractor New Holland TL-90 #10
Oh believe me before I broke the seals I would have done every bit of research possible both on the net and in libraries plus picking the brains of some real practicing diesel mechanics. I'm on the low end of the JD 50xxE series so I can probably get quite a bit more if I found I needed it. One thing I would do is look at the parts list of the various power levels to see when they change the turbo parts or if they do at all. Pumping in more fuel won't work if there is not enough air to mix with it.
Komatsu Midi Excavator (A51691)
Komatsu Midi...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
2023 John Deere 8R 280 MFWD Tractor (A53342)
2023 John Deere 8R...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
PENDING SELLER CONFIRMATIONS (A53426)
PENDING SELLER...
