Turn Signal Indicator
   / Turn Signal Indicator #1
Anonymous Poster
Epic Contributor
Has anyone experienced a problem with the turn signal indicator lighting up solid instead of blinking when the signal is turned on a BX2200? All signals work properly and left signal indicator blinks properly but the right one remains lit while the signal is on. Not that I will be using them but it is nice to have everything working properly. My dealer has no idea why this is happening!
I can't answer your question, but I suspect that there might be some sort of interaction between the hazard light and turn signal controls.
On the B7500 with the hazard flashers on, using the turn signals will cause the appropriate side to flash and the other side to be lit (without flashing). Since this sounds similar to what you are seeing, perhaps there is a fault in your hazard light switch... /forums/images/graemlins/confused.gif
Thanks for your response. I will look into that. I am not 100% positive but I believe that the indicator blinks properly when the hazards are on. I did not mention it in the previous post, but the right side was cross-wired at the rear blinkers when I took delivery and the fuse would blow each time the signal was turned on. Obvioulsy, the dealer did not take the appropriate time to test everything before delivery! I do not know if this has anything to do with it.
I have a B2910 and mine does the same thing. I read somewhere in the manual that it is normal for the other light to stay on when signal is turned on
Not sure if I made myself clear! I am talking about the indicator light on the dash staying lit (solid) not the other amber light in the rear. Sorry for the confusion.
   / Turn Signal Indicator #6
Hey guys:
My 2200 lights stay solid on the opposing turn indicator. Really bass ackwards but I am sure that they saved $$ by setting it up that way...
I checked my b2910 this evening. The light in the dash and light on ROPS stays on when one signal is flashing. Must be a Kubota thing.
   / Turn Signal Indicator #8
I had a similar problem when they delivered my MX5000. Turned to be wiring hooked up wrong at the factory.
Mike
Thanks for the input. Spoke to the dealer this morning and they are going to take a look at it.
   / Turn Signal Indicator #10
I had trouble with my BX2200 turn signals, and it turned out to be water sitting in the switch, had corroded the contact points of the switch.The angle that the switch is on allows the water to stay in the switch and collect .Remove your switch and open it up you will see what I mean.
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
JOHN DEERE/UNVERFERTH 1700/330 (A53084)
JOHN...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
