Turn buckle - stupid question
   / Turn buckle - stupid question #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
Ok, first off I know this is a stupid question but...
How the heck am I supposed to keep the turn buckles from working loose every 5 minutes on my new L3700. The jam nut seems to do about nothing. My old machine had the pin you ran through the turn buckle and that keep it from working its way loose. I am thinking of putting a pin hole through these so I can pin them in place or fork up the cash and put sliding bars on. Any thoughts?
THANKS
   / Turn buckle - stupid question #2
THANKS
Mine stay tight. Maybe you aren't tightening them enough?
   / Turn buckle - stupid question #3
I would agree it is a pain, but if you take a wrench to the jam nut and tighten it against the turnbuckle tightly, it will not come loose, at least mine dont. I dont really like having to carry the wrench, but it fits nicely in the toolbox:)
but I suppose you could drill a hole in the end of one of the bolts, and put in the hairpin like the little B series have, or spring for the telescoping stabilizers. I just cant spring for them right now, so I just tighten the nut!
James K0UA
   / Turn buckle - stupid question #4
I've always tightened them to about 20 ft-lbs, which keeps them snug. (My wrench is a foot long, so I can estimate things like that.)
Have you tried operating on flatter land? :)
   / Turn buckle - stupid question #5
use one drop, I repeat only one drop of Blue Loctite to solve that issue if getting it tight by hand is an issue and no more worries and you can still break it loose to reposition it if needed.
   / Turn buckle - stupid question #6
A small sash chain,cut just long enough,with a snap clasp on the end.Find an anchor point for one end and fasten the clasp on the handle of the turnbuckle. Quick and easy.It keeps the turnbuckle from rotating and it's easy to remove when you do want to turn it.
   / Turn buckle - stupid question #7
Now why didn't I think of that? Thanks:thumbsup:
James K0UA
   / Turn buckle - stupid question #8
THANKS
You have your answer, and you won't hate those turnbuckles every time you change implements.
   / Turn buckle - stupid question #9
Well, I looked carefully today, and there are already holes in the end of the bolts, for Hairpins. So I ran the nuts back up all the way, and put in some hairpins, this is the way my old b7500 worked, so I guess this can work on the L3400. I am going to give it a try. Lots easier to pull a pin and then turn the turnbuckle, than mess with a wrench and the nut. time will tell
James K0UA
I went and checked mine and I don't seem to have the pin holes - wish I did. There must me some little difference between the two. The Jam nut is a pain, I am all about adding sliders or drilling a hole for some hairpins!
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
LIGHT BAR AND WIRING (A50854)
LIGHT BAR AND...
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
Komatsu PC490LC-11 Hydraulic Excavator (A49346)
Komatsu PC490LC-11...
1975 Dodge 600 Grain Truck (A50514)
1975 Dodge 600...
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
