Turf Tires for a JM200LE
   / Turf Tires for a JM200LE #1
hbaird
Deadwood Falls Louisiana
Jinma JM200LE
Next spring I will have enough yard grass to start cutting with my Jinma 200LE. I can get a good Finish Mower locally. All I think I need for my tractor is to go over to Turf TIres. First do I need to replace front and rear rims? While I may need Ags on the rear from time to time I don't need them on the front ever. Will Turfs work on the stock front rims?
Harold
   / Turf Tires for a JM200LE #2
All four rims are typically replaced when changing over to turf tires. R3 tires are proporationately wider than R1s - on purpose - so rims for R3s and proportionately wider than rims for R1s. But don't lose sight of the rolling ratio. It's not as critical on 2wd tractors, but should be kept in mind when selecting which front size goes with which rear size.
If you plan to use your 200 in the winter, you may find yourself switching back to R1s on the front - till things dry up in the spring. Turf tires don't steer well in snow and mud.
//greg//
2019 Caterpillar 966M Articulated Wheel Loader (A51691)
2019 Caterpillar...
2011 Ford F-150 4x4 Pickup Truck (A51692)
2011 Ford F-150...
2016 Bad Boy 54in. ZT Elite Zero-Turn Lawn Mower (A53117)
2016 Bad Boy 54in...
2001 Ford Expedition (A51694)
2001 Ford...
2025 Safety Basket Forklift Attachment (A51691)
2025 Safety Basket...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
