ipwanab
Bronze Member
Are there any tire experts on here? I have looked evrywhere and can't find a definitive pressure recommendation on R3 41-14-20 Galaxy Mighty Mow tires. Tractor is 3033r with cab and 72d belly mower. This is the most common use for the tractor. Manual only shows maximum of 25 PSI on the rears. I let them down to about 5 lbs trying to get the tractor in my 7 ft garage. (No go).The side walls really didn't buckle until then. Called a tire shop and they had no advice other than "don't run bias tires too low or you will ruin the sidewalls". The tractor rides kind of like a conastoga wagon on concrete with 25 lbs. Any ideas?
