Tires Turf Super Lug tire for F 725 with side bagger?
   / Turf Super Lug tire for F 725 with side bagger? #1
SB2010
Arlington, WA
Deere F 650 tractor, Deere F 725 Front mower, Deere X 500, Kubota RTV, Kubota F2650 front mower, IHI mini excavator
Hi guys, I'm new to this forum, and sure would appreciate any information you could give me about changing out my mower tires. I mow about 5 acres, mostly hilly and bumpy using a John Deere F 725 front mower. Love the way the mower works, it's reliability, and great overall traction. But on hills, especially if the grass is wet, my original Multi Trac tires spin, sometimes even on dry grass going uphill.
I've just found this "Turf Super Lug" tire on a popular site, but don't want to order them until I know the exact dimensions of these tires. As the tread is a lug tread, and extends out from the tire nearly an inch (from reviews), I'm concerned about the lugs catching on the bracket that comes off my drive wheel to support the side bagging system I bought with this mower about 16 years ago. There is only シ" to ス" clearance between the tread and the bar or bracket that attaches to the hub of the right side drive wheel. Anybody out there who has changed out these original tires to a more aggressive tread pattern to improve traction on hills? Big concern is only the clearance factor. The measurements of the original tires which are 20x10x8 are: 9" across the tread, and 18 ス" tire height when fully inflated. Any help out there? Many thanks.
   / Turf Super Lug tire for F 725 with side bagger? #2
:welcome: from Ohio
Have you looked at RimGuard or or otherwise filling the tires?
That may solve the problem without changing tires out.
The tires are only 18" high, so RimGuard would only add a few pounds. After 16 years on gravel and grass these old tires are probably ready for a change, not much tread left on them. After careful measuring and more internet surfing, I'm not finding any tire that will replace these that I can use my bagger with. The local Les Schwab tire store here has one set of O.E.M. tires which would at least give me the same traction it had when new. Don't see any other viable option other than that so far. Thanks for you suggestion though.
SB2010
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
BE Quick Attach Snow Blade (A50514)
BE Quick Attach...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
GMC 3500 Ambulance (AS IS)(NO TITLE) (A50774)
GMC 3500 Ambulance...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2016 Chevrolet Sonic LS Hatchback (A50324)
2016 Chevrolet...
