number two
Veteran Member
- Joined
- Apr 2, 2007
- Messages
- 1,382
- Location
- Northern Lower Michigan
- Tractor
- Kubota B3030HSDC Kubota L2501HST
My friend finally dropped off my new Turf-Saver pipe for my new snowblower. I've been tearing up the driveway and blowing gravel,scratching up the new blower,skid shoes just don't cut it. I've finally got it on and will find out tomorrow how well it works. He made me one for my old B2660 blower and it worked well.
The pictures aren't real clear,but I've included several for good measure. The pipe greatly reduces the tendency of the blower(or plow blade for that matter) to sink into the soft,unfrozen gravel. Once the driveway is frozen,the pipe can be removed. Sometimes they're left on all season in a mild winter.
We used a piece of 1" galvanized pipe I had on hand. He cut a slit the length of the pipe the width of the cutting edge with some very good 3" cutoff wheels. Then the end attachment pieces were made from some flat stock he had around,welded to the ends of the pipe. We then installed the pipe on the blower and bolted it to the sides through the skid shoe bolt holes. The flat cutting edge was different from any pipe we've made up before. Plows and my older blower had the blades angled down toward the ground,while the B2782 blower's edge is parallel to the ground. Hence the narrow slit so the pipe wouldn't go on too far and hit the blade attaching bolts. Sorry if I got a little long winded. Good Day.
