Turbo for the RTV900?
   / Turbo for the RTV900? #1
pappy19
Garden Valley, Idaho
Kubota RTV 900
I overheard someone at the local hardware store saying that there was an aftermarket turbo for the RTV 900. Does anyone know anything about this?
   / Turbo for the RTV900? #2
There is a turbo kit for the RTV, but it is designed to improve performance at high altitudes, not generally enhance performance at lower altitudes. The general impression is it won't do much for sea level performance. There is a whole thread on this subject on the other forum. See: Compact Tractor Review - Kubota RTV Owners Group
Andrew
   / Turbo for the RTV900? #3
Check out the last Dyno on the RTV1100, Stock vs Turbo.
Also, The emissions was reduced from 18.2% Peak Opacity down to an amazing 11.2%
You can see it on our site rtvturbo.com
Or Direct:
Kubota RTV1100 Turbo -Vs- Stock - 12-02-10 With Smoothing
Travis Imel
travis@swaginc.com
swaginc.com
2010 MQ POWER 25KW GENERATOR (A52472)
2010 MQ POWER 25KW...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A52748)
LIKE NEW 2023...
14" Pipe Ditch Lift Pump (A50121)
14" Pipe Ditch...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
80in HD Tooth Bucket with Side Cutters (A52748)
80in HD Tooth...
