Tuning up my 1520
   / Tuning up my 1520 #1
jon edwards
Lewistown, Montana
Case Farmall 75C, john deere 1520, Polaris 900 XP
A friend is helping me work on my new (to me) 1969 1520. Apparently the governor doesn't work correctly. The guy I bought it from had a bungee cord on it to keep it off. I ordered a carb kit and electronic ignition. Any ideas on what to do with the governor? Again I'm not a mechanic, so I don't know if I discribed the situation correctly.
   / Tuning up my 1520 #2
What brand of engine does this unit have? Was the bungee cord used to keep the engine at full throttle? That is never a good thing, it could have been oversped. Your governor could possibly be blown apart inside the engine.
   / Tuning up my 1520
I checked the engine. It is a John Deere 3 cylinder gas engine. The numbers on the side are T26936/T30000. Near the numbers it says John Deere High Altitude Pistons. The guy I bought the tractor said when he bought it five years ago the motor was blown. He rebuilt it. He said he put $2900 dollars in parts into the engine including harded piston sleeves to run on unleaded gas. He said he has used it for the last five summers haying and it works well.
He said he thought the govenor might have malfunctioned prior to his getting the tractor and he had it bungeed to prevent that from happening again. We serviced the tractor and it starts well and seems to run well, but you need to run it with the choke on, I should say it runs better that way. I bought the previously mentioned stuff and we want to get it running correctly.
Obviously I hope there are no parts floating around in the engine. It does seem to run really well other than the above mentioned stuff. Any advise would be appreciated.
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
CASE TR310 SKID STEER (A52705)
CASE TR310 SKID...
SCAN TO RECEIVE TEXT UPDATES (A52705)
SCAN TO RECEIVE...
Electric Mobility Scooter (A54815)
Electric Mobility...
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
