I wanted to share my solution for making it possible to perform oil changes on my K46 / T40J transaxle without having to take it off of my mower (John Deere D130).
I documented the modification on YouTube: https://youtube.com/playlist?list=PLd1vGGfDybyGtF_MG0fJscUE2pO8VWHN0
I drilled and tapped drain plug holes, which many other people have done. What is unique about this mod is that I also converted the vent hole into an external expansion tank.
I’m able to fill the trans by pumping the oil in through a drain plug hole using a hand pump that is typically used for the lower unit on outboard motors. To prevent the oil from draining back out when unscrewing the pump, I temporarily blocked the vent cap on the external expansion tank to create a fluid lock. This let me put the drain plug back in without losing all the oil that I just pumped in.
Hope someone finds this useful!
