Tub reglazing vs. lining
   / Tub reglazing vs. lining #1
DrRod
Platinum Member
Ellicott City, MD - Farm in Orbisonia PA (south ce
John Deere 4110
Greetings,
Just bought another place and the tub is rather yucky. Several people has suggested reglazing or putting on a custom molded vinyl liner. Reglazing is $350, the liner is $850. Anyone have any experience with these options or even just an opinion? Thanks for your thoughts.
   / Tub reglazing vs. lining #2
If it's just 'yucky' & you have someone reputable doing the re-glazing it should come out fine. If the 'yuck' includes rust spots or rusting around the drain hole or other fixtures that go thru the porcelain then I'd probably go for lining it. From what I've seen the rust is never entirely abated and it comes back to haunt you in the not too distant future.
Good luck, -Norm
Thanks for the thought. Since posting this I took a look at some websites and found that bathtubs start at about $250. Even with a slight upgrade -- say a $350 tub -- and two man-days of install labor I should come out at or below $850. Makes me wonder why the liner makes any sense.
   / Tub reglazing vs. lining #4
I have never had any luck with "Re-glazed" tubs...they look great for a while until the glaze starts coming off...usually around the drain.
About 10 years ago, we began replacing bad tubs with Kohler Cast Iron...and it has proved to be money well spent. The only downside is the weight and moving it into position.
   / Tub reglazing vs. lining #5
Must have to do with labor rates in our area - pretty pricey up here, lots of 2nd homes, etc. A re-lining guy wanted $2500 to do a tub and shower surround for one of my customers (less than 2 days work). The plumber (the 4th one they called, the only one that actually called back) wanted almost twice that to replace the tub & use a corian-type material on the wall. They went the liner route.
-Norm
   / Tub reglazing vs. lining #6
I had a neighbor reglaze their tub and they were very pleased with the result... even a couple of years later. The thing that worrries me about the liners is mold. How do they prevent mold from growing between the old tub and the liner?
   / Tub reglazing vs. lining #7
I just had a fiberglass tub/shower combo reglazed due to a crack on the bottom of the tub. The cost to fix the crack and re-graze the entire combo unit was $425. The crack wasn't leaking but I was worried it may in the future and damage the ceiling below. I also looked at replacing the whole tub/shower unit but I figured the cost to replace the tub and new surround would be a min. of $800. The tub looks great and the only issue will be how long it last.
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A52141)
2004 HYUNDAI...
2014 FREIGHTLINER M2 REAR LOADER GARBAGE TRUCK (A51219)
2014 FREIGHTLINER...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
John Deere 506 3 pt Mower (A50515)
John Deere 506 3...
2016 CATERPILLAR 262D WHEELED SKID STEER (A51242)
2016 CATERPILLAR...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
