TT75A 3 pt. hitch problem
   / TT75A 3 pt. hitch problem #1
muskeg_mapper
I've been having a problem with the 3 pt. hitch on my new TT75A. When an implement is attached (currently a snowblower) it will raise ok, but when I lower it, it won't lower smoothly, it jerks and stops all the way down. Is there some sort of adjustment I can make or is there air in the system? Any ideas?
   / TT75A 3 pt. hitch problem #2
I'm sure there is an adjustment (normally near the front of the seat) that will adjust how fast the 3PH is supposed to drop. It's just a needle valve and only effects lowering the 3PH.
What you describe really doesn't sound like that. It sounds like you are saying that your 3PH will not lower until the lever is all the way down and then the 3PH just falls. Do you have draft control? Draft control can sometimes act similar to that. You may have a lever somewhere to change between draft control and position control. I'm not sure of all the features of the TT75A, so I may be giving bogus info, but those are the two things that come to mind based on my experience.
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2012 SHOP BUILT  TANK MANIFOLD (A53843)
2012 SHOP BUILT...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
Kubota BV4160 (A50123)
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
