TSP to clean out diesel tractor tank!!
   / TSP to clean out diesel tractor tank!! #1
WilliamBos
Super Member
Innisfil, Ontario, Canada
MF 1635 12x12 Powershuttle
Hey,
We are swapping a new fuel tank into a Tractor. ( MF35, 3 cyl Perky. ) The tank we are going to swap in is a used one that has sat around for a while. I would like to clean it out myself, but don't know what to use. Someone told me that TSP will do the job well, and I was wondering what you folks on here thought. Should I rinse it out with diesel after, just to make sure NO TSP is in the tank?
Thanks,
Will
Hey,
Thanks,
Will
   / TSP to clean out diesel tractor tank!! #3
</font><font color="blue" class="small">( Hey,
Thanks,
Will
)</font>
My gut tells me it is a bad idea. But call the manufacturer.
Bob
   / TSP to clean out diesel tractor tank!! #4
Thanks,
Will
)</font>
Bob
   / TSP to clean out diesel tractor tank!! #5
Suggest you take it to a radiator shop. They can boil it and then you can coat the inside with an epoxy lining. If you "guess" you'll probablly end up sorry you did once its on the tractor. BobG in VA
   / TSP to clean out diesel tractor tank!! #6
   / TSP to clean out diesel tractor tank!! #7
If you want to seal the inside of the fuel tank I highly recommend the products that this company makes tank sealant
This is the same company that makes "paint over rust" epoxy. I have used the POR-15 paint and it works very well, just don't let any of it dry on your skin cause nothing will take it off once cured. /forums/images/graemlins/smile.gif
   / TSP to clean out diesel tractor tank!! #8
1979 MACK R MODEL WINCH TRUCK (A53843)
1979 MACK R MODEL...
2018 KENWORTH T270 SERVICE TRUCK (A51406)
2018 KENWORTH T270...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A54607)
2013 KENWORTH T680...
2016 Case 821F Articulated Wheel Loader (A54811)
2016 Case 821F...
2005 Mitsubishi Lancer ES Sedan (A54815)
2005 Mitsubishi...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
