TSC 14' Logging Chains On Clearance
   / TSC 14' Logging Chains On Clearance #1
Hdoilcan
USA
2018 KIOTI CK3510SE CAB, 2475L BACKHOE, 72 BOX BLADE, 72 REAR BLADE, 72 LANDSCAPE RAKE, 1,250 LB 55 GAL DRUM BALLAST, 2018 FERRIS IS 700Z, 26HP 810 VANGUARD ENGINE
Would just like to pass a good deal on to everyone. Tractor Supply has 3/8" X 14' logging chains marked down from $47.99 to $19.99.
I thought it was a good deal so I bought 8 of them. They come is a cheap black plactic box that snaps close and has a handle for carring.
   / TSC 14' Logging Chains On Clearance #2
Wow you got a deal,you couldn't go wrong with that.
   / TSC 14' Logging Chains On Clearance #3
I looked them up and they are grade 43 with 5400 lbs working strength. Not a bad price if you can use that rating of chain.
   / TSC 14' Logging Chains On Clearance #4
Local stores all sold out....bummer.
   / TSC 14' Logging Chains On Clearance #5
Looks like there only $15 off you can order them on line
Sent from my iPhone 5 using TractorByNet
2014 Infiniti QX60 SUV (A53424)
2014 Infiniti QX60...
CATERPILLAR HANG ON 71" WHEEL LOADER FORKS (A51406)
CATERPILLAR HANG...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
2016 HINO 195 16FT BOX TRUCK (A54607)
2016 HINO 195 16FT...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
(INOP) 2016 AUTOCAR EXPEDITOR GARBAGE TRUCK (A54756)
(INOP) 2016...
