TS3510 trans oil change problems
   / TS3510 trans oil change problems #1
freedomlives
Platinum Member
Husak, Slovakia, EU
Iseki TS35F, Goldoni Special 140 with powered trailer -- Goldoni Special 128 -- Goldoni Uno for mowing -- Czech Vari system
I drained the old oil that the importer put it, as it was 90 weight and the manual calls for 140 weight, and I feel like the gears are noisy. Out came 13 liters, capacity in the manual is listed as 16.
I pumped in about 10 liters. Let it set awhile. Then I unscrewed the plug next to the floorboard for checking the oil, and it came out. So I connected a nipple and a hose to collect the oil, and eventually to speed it up ran the pump in reverse on that nipple, but the oil kept coming. I sucked 4 liters out, then stopped. I'm stumped-- is it somehow pulling oil up from the case? Let's say I pump in a full 16 liters, is there actually some problem that's going to occur if the transmission is over filled?
New 4-235/80R16 Montreal Trailer Tires (A50774)
New 4-235/80R16...
2008 Bobcat S250 Skidloader (RUNS) (A50774)
2008 Bobcat S250...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
2003 Fleetwood 2 Axle Camper (TITLE) (A50774)
2003 Fleetwood 2...
CAT 299D2 (A47384)
CAT 299D2 (A47384)
