TS1910 Torque Specs
   / TS1910 Torque Specs #1
MightyMachine
North Carolina
Iseki TS1910
Does anyone know the torque specs for the bolts at the back of the tractor which hold the drawbar bracket and are around the PTO?
   / TS1910 Torque Specs #2
If your referring to the hitch plate that bolts directly onto the rear of the transmission, it's held on with both M12 bolts and M12 studs with nuts as far as I can make out.
The table in the service manual should two charts one for 4T bolts & nuts and another chart for 9T bolts and nuts & 7T nuts.
Tightening torque (4T) M12 is 434-520 lbs-in (9T) M12 is 781-954 lbs-in. I would assume that the bolts and stud/nuts for this plate are 4T as there is no notation against them in the parts manual, look like only the 9T are noted.
Hope this helps.
Thanks greatly John. Would you happen to know the ft./lb. conversion for these torques? Both of my torque wrenches are in ft./lbs.
Thanks again.
   / TS1910 Torque Specs #4
The Goggle calculator has the following conversion.
1 pounds inch = 0.0833333333 foot pounds
Which makes them 36.16-43.33 & 65.08-79.79 foot pounds respectively.
Does this sound about right??
I have never had to convert these before. It certainly sounds right. Thank you so much John. /forums/images/graemlins/grin.gif
2013 FORD F-650 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 FORD F-650...
2014 TROXELL 130BBL VACUUM TRAILER (A52472)
2014 TROXELL...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
KSI Conveyor (A52748)
