TS1910 Loader Mount
   / TS1910 Loader Mount #1
JJPWAus
West Australia
Iseki TS1910, JD110
Been looking to build a loader for my 1910 and have received a set of plans from PF engineering, which look ok so far. I need to design the main underbody mount between the two upright posts, but would like some advise before I get too carried away. Looking on the tractor there are three 14mm threaded holes on each side of the clutch bell housing(two down low and the third towards the top of the housing. Are these suitable to take the weight of a loader? It looks pretty heavy duty material to me and at first glance looks like the only option I can come up with. /forums/images/graemlins/confused.gif
Can anyone shed some light on how their loader is mounted, any photo's would also be great (beats a thousand words)??
Last thing I need is to do major damage to the bell housing.
Any help greatly appreciated.
   / TS1910 Loader Mount #2
Check my reply to another post. I made brackets from 3/8ths bar stock. Also there is a 1x4"steel bar that crosses
in between the two brackets underneath the tractor. In the link in the other post for hoye tractor there is also a clear pic of loader mount. Usually the mounts mount to the bell housing and front frame. I have also seen ones with other supports going to rear axle area. post
Mark, Many thanks for your help.
   / TS1910 Loader Mount #4
You also might want to check out www.machinebuilders.net There are people there that have built loaders and backhoes from plans also that would probably be able to answer most of your questions
about fabrication etc.
2014 KENWORTH T680 (A52472)
2014 KENWORTH T680...
2002 Freightliner FL70 Elgin Street Sweeper Truck (A51692)
2002 Freightliner...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
Hyster H225E (A47384)
2015 Ford F-250 Knapheide Service Truck (A51692)
2015 Ford F-250...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
