TS1610 tick over speed
   / TS1610 tick over speed #1
Nigelm
Cheshire
Iseki ts1610
What tickover speed should I expect, at 1000rpm it is OK and steady, any less and it gets unstable. I have changed the fuel filter and bled the fuel pump and changed the air filter but this made no difference.
Otherwise the engine starts and runs fine
   / TS1610 tick over speed #2
I think that is normal. Below 1000rpm it is unstable. It gets a little better after running the tractor for a while when the engine is hotter, but not much better. When hot my TS1610 low idle speed is about 800rpm.
That ties in with what I am finding.
The hand throttle on minimum is set too low and the engine cuts, do I adjust this on the throttle linkage or can you set a tick over speed on the fuel pump.
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
Danuser 3 pt Post Hole Digger (A50515)
Danuser 3 pt Post...
2023 John Deere 8R410 MFWD Tractor (A52128)
2023 John Deere...
2018 CATERPILLAR 259D SKID STEER (A51242)
2018 CATERPILLAR...
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
Payment Terms (MUST READ) (A50774)
Payment Terms...
