TS1610 PTO Speed control
   / TS1610 PTO Speed control #1
rich_ncal
Northern California
TS1610
The PTO selection lever on my TS1610 has four positions. There is a new looking decal listing positions 1 -4 for the PTO. However looking at the PTO in operation it does not look little the decal is correct. #1 seems faster than #3.
Please some feedback on the correct positions.
Rich S
   / TS1610 PTO Speed control #2
I have a TS1910 with what sounds like the same mis-labelling. For the first winter I used the snowblower with the PTO in the #1 (down and out) position as I read on TBN that this was the 540 rpm position. The following summer, with the Iseki tiller in place, I wanted to see what some of the other speeds were like on the PTO and was surprised to see that the #3 PTO speed (lever down and in) was slower than the #1. I read on TBN that most North American PTO instruments are not made to handle PTO speeds greater than 540 and I have not heard that the Isekis were made with a speed lower than 540.
The following winter I used the # 3 PTO speed for the blower and the snow didn't seem to blow as far but it still did the job.
There is a fancy instrument that can be used to check rotation speeds (name escapes me) but for now, as long as it tills or blows in the slowest PTO speed, I will use #3.
Cheers!
   / TS1610 PTO Speed control #3
I have a mechanical Tach that has a rubber tip. You put it on the end of the shaft. It tells the rpm. Some of the smaller Isekis had a slower than 540 speed.
   / TS1610 PTO Speed control #4
I have an original decal on my TS1610. 1st is down and in, 4th is down and out, 3rd is up an in, and 2nd is up and out.
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52748)
2003 International...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2025 CFG 48in Forks and Frame Skid Steer Attachment (A50325)
2025 CFG 48in...
Electric Mobility Scooter (A51694)
Electric Mobility...
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
