TS110 Transmission Issue
   / TS110 Transmission Issue #1
whocares99
deep river, ontario
kubota bx22
Our snowmobile club runs a TS110 with tracks (SurTrac conversion) as a trail groomer. This past season, the high/low range cable broke and we could not shift ranges. Have replaced the cable and we found a new issue. The transmission seems to work fine in the low ranges gears 1 to 8 but we have an issue in the high range.
In the high range we can shift up and down through 1 to 4 without problems. When we shifting into high range gears 5 to 8 the tranny acts strange. Can shift up from 5 to 8 okay but then then the tranny shifts back to 5 by itself. Any ideas on where to look for the problem.
Even if we can fix it, it won't be a problem because we normally only groom in the high range gears 1 to 4. Not enough power to groom in the higher gears when cutting and pulling a heavy load of snow.
2013 BOBCAT S630 (A52472)
2013 BOBCAT S630...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2015 F-550 Bucket Truck. (A52748)
2015 F-550 Bucket...
434668 (A51572)
434668 (A51572)
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
