hoppy50680
- Joined
- Oct 26, 2004
- Messages
- 7
I bought this tractor in a crate. first thing that happened the key would not turn in the ignition. reason was it was filed incorrectly at the factory. whoever put it in the key machine had it in the wrong position. luckily I have had some expierence re keying locks so fixed it myself.. next thing the power steering line was leaking at the solder joint, again a factory problem, had to buy a new line . then the glow plugs were blowing the main fuse, so I had to make a seperate circuit for that... then the reverse idler gear bearing went out. this I didnt feel I was qualified to fix so I took it to an independent tractor repair place to have it fixed. what happened was the retaining ring was installed backwards which allowed the gear to slide down the shaft, again, factory foul up. this repair is gonna be an expensive one.. I contacted the factory to get some help paying this bill but have no response from them. I didnt actually expect one but was worth a try.. this little tractor is a heavy built one, and very handy, but I kind a wish I would have had more money at the time and bough an american made one. not that they dont have troubles too, but when you need parts their close by, and I would have had a warranty also.. I hope that people looking for a new tractor will read this before making up their mind on which brand to buy..
hoppy50680
hoppy50680
