TS 1700
   / TS 1700 #1
dstogsdill
I am looking for a clutch and pressure plate fot this tractor. Does anyone have any info? It is stuck in gear, tried everything i know to break it loose. Even hit the brakes hard enough i broke the right brake drum, looking for one of those also.
   / TS 1700 #2
I have found the best way to break a clutch loose is by starting it in first gear with a trailer load attached, driving it away with the clutch in and holding the clutch in while climbing a hill and varying the accelerator. Gunning the engine, backing off on the throttle will often break it loose. You have to have the clutch in the entire time. Use a dry, paved road if possible. As always, be cautious and aware of what's happening around you.
   / TS 1700 #3
If it is not a frozen clutch, your shift yoke is probably jammed and you should pull the transmission crown plate (shifter) off. Sounds like your clutch is probably frozen to the flywheel though.
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
NEW Woods Reverse Rotation 5ft Tiller (A52748)
NEW Woods Reverse...
2015 ISUZU NPR 16FT BOX TRUCK (A52577)
2015 ISUZU NPR...
2018 FORD F-150 (A52472)
2018 FORD F-150...
