TS 1610 charging circuit
   / TS 1610 charging circuit #1
eppoh
Texas
Iseki TS1610
Does anyone know if the key switch on the TS 1610 must be to the "on" that is to the right position, for the charging circuit to be energized? I mow only during daylight and don't want to run the lights.
   / TS 1610 charging circuit #2
On the TS1610 there are three on positions for the key "on electrical power on", "on with lights on high beam" and "on with lights on low beam". So you should be able to operate the tractor with the key on and the lights off. I think it will charge with the key in the off position, but the operator manual says not to do that. The operator manual does not say why this shouldn't be done, but I think it is because with the key in the off position the warning lights for water temperature, oil pressure and alternator may not work.
Electrical power on with the lights off should be the first position of the key next to off.
John Deere HPX Gator (RUNS) (A50774)
John Deere HPX...
Army Semi Trailer (A50774)
Army Semi Trailer...
2010 Dodge Grand Caravan SE Van (A50324)
2010 Dodge Grand...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
2015 FREIGHTLINER M2 DAY CAB (A52141)
2015 FREIGHTLINER...
Tennant Floor Sweeper (A50322)
Tennant Floor...
