TS 100 Master cylinder leak
   / TS 100 Master cylinder leak #1
musselmark
grand tracadie PE
'05 NH TN75DA
A buddy has a TS 100 and the master cylinder is leaking where the pedal pushes in the piston. Can these be repaired with new seals. Dealer says he has to buy a new master cylinder for $800.00 Thanks
   / TS 100 Master cylinder leak #2
Re: TL 100 Master cylinder leak
A buddy has a TL 100 and the master cylinder is leaking where the pedal pushes in the piston. Can these be repaired with new seals. Dealer says he has to buy a new master cylinder for $800.00 Thanks
The later years were TL100A. In either case Messicks shows the master cylinder at $326. Don't see any exploded view that shows parts for it.
Actually I just found a kit on ebay for 67 bucks.
Cheapest brake master I could find on ebay was around 400 Canadian delivered. The clutch ones are cheap
   / TS 100 Master cylinder leak #7
G'day if you are going to rebuild one then do both while you are in there and be sure to use the correct fluid for it I think it should be a mineral fluid IIRC
Jon
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
2015 TAKEUCHI TB260 EXCAVATOR (A51246)
2015 TAKEUCHI...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
BOX OF SCHUMACHER 6A BATTERY CHARGERS (A51248)
BOX OF SCHUMACHER...
