trying to narrow down choices between 3 brands/8 used tractors- opinions welcome! :)
   / trying to narrow down choices between 3 brands/8 used tractors- opinions welcome! :) #1
maxreps
64 AC D15 II
Hi everyone,
I'm joe average homeowner with 10 acres, mechanically inclined(auto head gaskets, engine rebuilds when I have to...). I want another tractor as my '64 Allis D15 II(gasoline) has a cracked block. *Tractor will be used for about 2-3 acres bushhogging, grading/scraping/snow removal of driveway that's 1800' long w/200' of 30-35% grade(20 degrees approx) and anything else I may putt around doing*
All below are diesel and have a front loader. Unless research is wrong, Mahindra has no DPF but Deere does and I'd like to avoid DPF. Due to stories of replacing the unit in 5 years for $1500-2000. I have prices on some but am waiting to hear on others marked TBD. Please give recommendations of your top 4 picks and a fair price for each.
2019 Mahindra 1533 - $17k
2016 MAHINDRA 2540 - $TBD
2014 Mahindra 3016 - $11k
2009 MAHINDRA 4110 - $TBD
1986 Massey Ferguson 294 - $TBD
2005 Kioti DK35 - $12k
2016 JOHN DEERE 4044R - $TBD
2003 JOHN DEERE 5320 - $TBD
   / trying to narrow down choices between 3 brands/8 used tractors- opinions welcome! :) #2
I'm joe average homeowner with 10 acres.
Mahindra has no DPF but Deere does and I'd like to avoid DPF due to stories of replacing the unit in 5 years for $1500-2000. [/U]
I am neutral on emission control system technology; whatever works.
However, there are numerous reports on T-B-N of Mahindra sales personnel telling tractor shoppers that Mahindra tractors do not have a DPF and do not regenerate, both true; implying Mahindra is Tier IV compliant without emission control components. Not true, of coarse.
Beginning about thirty-three horsepower most tractors have Diesel Particulate Filters.
A few Tier IV compliant tractors between 26 and 75 hp use DOC (Diesel Oxidation Catalyst) conversion. Mahindra is one. Mahindra DOC is of similar construction to DPF. Both DPF and DOC are honeycomb ceramic filters which supersede the muffler. The DOC forces engine exhaust over a honeycomb ceramic structure coated with platinum, palladium, and rhodium. These catalysts oxidize carbon monoxide and hydrocarbons into carbon dioxide and water at hot exhaust temperature.
Mahindra has a DOC oven hot all the time, DPF tractors have an oven hot intermittently.
There is no free lunch.
The average residential tractor operates sixty engine hours per year, according to industry surveys.
3,000 hours DPF Life / 60 hours = 50 years of residential use prior to DPF replacement.
Diesel Particulate Filter supersedes tractor muffler.
At some point in time DPF needs to be replaced.
At some point in time tractors with mufflers need the muffler replaced.
At some point in time DOC needs to be replaced.
Tire wear and tire replacement will cause as many headaches and more expense than DPF/DOC for most long term compact tractor owners who read and comprehend their Operator's Manual.
For a commercial farmer operating tractor engine 300 to 400 hours per year DPF/DOC will require replacement more often than once in fifty years.
   / trying to narrow down choices between 3 brands/8 used tractors- opinions welcome! :) #3
Allis D15 gas is around 4,000 pounds, bare tractor weight, 2-WD.
Allis D15 gas is 50 to 55 engine horsepower.
When considering a tractor purchase, bare tractor weight first, tractor horsepower second and (narrowly) rear wheel ballast third.
Has Allis met your needs?
   / trying to narrow down choices between 3 brands/8 used tractors- opinions welcome! :) #4
Bare tractor weight FIRST is Jeff's personal opinion. There are many discussions on weight VS HP. If you've been happy with an AC D15, anything will be an upgrade. I don't mean that as a bad thing, tractors have came a long way since the 1960's.
Get the size/HP you need, you can always add weight if need be.
If you want to stay away from emissions (I know I do) you can always find a low hour tractor before emissions were on them.
   / trying to narrow down choices between 3 brands/8 used tractors- opinions welcome! :) #5
To me there is no discussion. Get the weight you need for the tasks...get he HP you need for the tasks.
So you have 2 acres of mowing, under 1/2 mile of gravel roadway to maintain. You want a front loader, but havent listed any tasks that would directly require it. I recommend listing out all the tasks that you want to accomplish with the machine (whether 1 time or repeated like snow removal). Then you can narrow down weight, HP, implements, tractor specs.
Also where are you location wise? How much snow in a season? How wet is it there?
Thanks for the DOC information Jeff, seems like a catalytic converter as used by automobiles. I updated the tractor weight/hp below also
The D15ii mostly did what I needed but occasionally it struggled. I got when 42 years old with no knowledge of the engine condition(never checked compression or leakdown). Typical age issues...iffy brakes, fair hydro function, who knows about power output due to wear.
The AG rears would spin when the 5' box scrape was full of dirt. (the driveway hill gets wrecked by heavy rainwater due to the hill grade and length). I had no loader but want one now due to snow removal, we had 14" in january this year(central NC). I have no direct knowledge of the correlation between 4wd vs 2wd effectiveness(assuming bare weight and power were the same). I've heard some say that a 35hp 4wd tractor will equal a 45hp tractor 2wd of the same weight but have seen no tables or proof that seems legitimate.
Two of the Mahindras in my list are mfrd by TYM, I've read that non-TYM products are better. Any truth to that at all?
I used tractordata for spec info.......
2019 Mahindra 1533 - $17,000 mitsu/34.5hp/3164lbs
2016 MAHINDRA 2540 - $TBD TYM/40hp/3285lbs
2014 Mahindra 3016 - $11,000 mitsu/28hp/2437lbs
2009 MAHINDRA 4110 - $TBD TYM/41hp/3969lbs
1986 Massey Ferguson 294 - $12,500 67hp/6720lbs
2005 Kioti DK35 - $12,000 35hp/3475lbs
2016 JOHN DEERE 4044R - $TBD 43.1/3370lbs
2003 JOHN DEERE 5320 - $TBD 64hp/4891lbs
   / trying to narrow down choices between 3 brands/8 used tractors- opinions welcome! :) #7
I've heard it said a 35hp 4wd tractor will equal a 45hp tractor 2wd of the same weight but have seen no tables or proof that seems legitimate.
Nor have I seen proof due to multiple, ever changing variables affecting tractor traction.
So qualified, not a bad analogy.
I believe TYM Mahindras have DPF consistent with other TYM TYM tractors, not DOC like heavier Mahindra Mahindra tractors.
   / trying to narrow down choices between 3 brands/8 used tractors- opinions welcome! :) #8
Out of that list, assuming condition is good, the MF 294 would be my pick, those were a solid tractor built by Landini, that basic design was sold well into the 2000's in Landini colors (Evolution series i.e. 8865) Perkins power and completely mechanical powertrain. Average mechanic could fix it too, nothing too complicated.
Most of the other tractors on your list are toy sized, 294 is a full size utility.
The 294 is in fair condition for a 33 yr old tractor. I'm a bit leary of buying an old diesel mainly because so many people use ether on them as they age. I'm sure it was solidly built though. The JD 5320 is next closest to the MF in power/weight. Half the age..
   / trying to narrow down choices between 3 brands/8 used tractors- opinions welcome! :) #10
Depending on price, I like the Deere 4044R
  • Better reputation than Mahindra
  • Newer than Massey
  • More Powerful than Kioti
2002 Fleetwood Expedition 36ft Motorhome (A51694)
2002 Fleetwood...
2020 KENWORTH T680 (A52472)
2020 KENWORTH T680...
2013 FOREST RIVER (A52472)
2013 FOREST RIVER...
2016 TROXELL 130BBL VAC TRAILER (A52472)
2016 TROXELL...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2023 Dynapac cc900 Double Smooth Drum Roller (A51573)
2023 Dynapac cc900...
