Trying to level gravel drive need technique help
   / Trying to level gravel drive need technique help #1
widmn
Nevada
JD870
I am using my loader & 4410 to spread #3 gravel (3/4" to fist size). It doesn't spread all that well. I have tried putting the edge of the bucket down and moving forward and backward but it doesn't work very well. Tried the bucket level also with worse results. The stuff is heavy and doesn't want to move unless you dig in and pick it up. Suggestions?? Do I really need a box blade or grader?
   / Trying to level gravel drive need technique help #2
"(3/4" to fist size)"
The fist size ones are the trouble makers.. going backwards w/ the FEL does seem to be the best method for smoothing.. try w/ a flatter angle on the blade. Those big gravel have to be worked hard.. doesn't flow like crush-run.
   / Trying to level gravel drive need technique help #3
I have had nearly 20 years experience of creating and maintaining a 1/4 mile gravel drive. I'm in the process of concreting it now, but due to the huge expense of doing so, I still have gravel most of the way. /forums/images/graemlins/blush.gif
I can't tell you if my method is best or not, but it is through trial and error. I do have a very smooth and flat driveway none the less.
I have a rear blade, a FEL, and a 6' box scraper. By far, the box scraper is the preferred tool to create and maintain a gravel driveway. About every two or three years, I have to use the box scraper to pull the gravel back in from the sides from where it has been scattered out. I then grade those back into the driveway.
When I started the driveway, I first scraped off all of the grass and sod that was present. Doing so also began the levelling process. I then laid down about 3 inches of #2 gravel. This is roughly golf ball sized gravel. That was followed up by about 4 inches of #5's. This gave me a firm bed. A few months later I put down about 4 inches of #53's. This is the same as the 5's, but the 53's have lime mixed in. The 53's pack in well and seal up the surface fairly well. Skip ahead several years (and several tri axle loads of 53's for maintenance) and I now have been using #9's. The 9's are smaller and make for a smoother surface.
2004 Kia Optima Sedan (A51694)
2004 Kia Optima...
2019 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2019 Caterpillar...
NISSAN 80 PROPANE FORK LIFT (A53426)
NISSAN 80 PROPANE...
2020 Nissan NV200 Cargo Van (A51692)
2020 Nissan NV200...
2000 Mack CH613 Day Cab Winch Truck (A53117)
2000 Mack CH613...
30in Forks and Frame Mini Skid Steer Attachment (A51691)
30in Forks and...
