Trying to find the right tractor...
   / Trying to find the right tractor... #1
bige1973
Dothan,Al
I just bought 12 acres of land and have no idea what kind of tractor to buy. The land was clearcut about 15 years ago so it is mostly underbrush and rotten limbs and stumps. I would like to eventually fence in the property so an auger will be important along with typical bush hogging, box blade, etc.... The only other thing I would like to be able to do is use it to mow my lawn with some type of finishing mower. Any advice given with regards to size, type, etc...will be appreciated.
   / Trying to find the right tractor... #2
Mabe like a John Deere 970 I have one good tractor for you uses accept for mowing a regular lawn.
   / Trying to find the right tractor... #3
You are going to need HP to cut the brush. The rule of thumb is 1 hp for each foot of brush hog width. A 5 ft hog will need 25 hp min. I would be looking at 30 to 35 hp. for a 5 footer, no telling what you may dream up next week and you do not want to be short on hp. Yes, you can push it, but why?
   / Trying to find the right tractor... #4
My new 2520 has worked very well on my 22 acres of hilly terrain and cutting my grass. Bigger would have been nice but was not an option.... Good luck on your search!!
   / Trying to find the right tractor... #5
All depends on your price range, mechanical ability, comfort level ect. The numbers I am quoting are real in my area, there is always someone telling you they can get a new JD 4320 with loader and mower for less but lets be realistic here, you may get it for a little less, but not much. As for used, I can find a pile of junk, or buy one from my uncle for a little less, but realisticly for a working tractor on the street?
New JD 4320 is what I want, but will probabaly never get.
$30,000
JD 790 (3005 now I think) is what I got, real nice 4x4 with loader, works hard, easy operation and maintenance, reasonable price.
$20,000
Thousand series Ford, New generation JD 1020, real nice older tractors. Independent PTO nice option, not as comfortable, no 4x4, heavier for mowing lawns, real workhorses.
$7000
Ford 8n, Fergusen TO, still real workhorses, transmision type PTO, I work withan NAA (next gen 8n) weekly, even choose it over my JD a lot of the time.
$2500
Farmall H, Allis Chalmers WD, same as 8n except no 3 point hitch, Implements must fit tractor and are getting harder to find. I also have one of these and use it a lot for drawbar work (mowing hay, baling hay, chopping green forage, ect) but it is much more limited. You can get aftermarket 3 point hitches for them for $1000 but thats a lot of money to put into an old tractor.
$2000
Just my 2 cents. Good Luck!!!
   / Trying to find the right tractor... #6
I'd suggest you need something with at least 30 hp, but equally important, something large enough to handle a rear blade and a good front end loader (FEL). The FEL will be extremely useful for your brush clearing and land levelling chores. The more hp you have, the quicker you can get the work done.
My preference is Kubota, but the other major manufacturers also make fine equipment. Finding a dealer who is competent and honest and finding a brand and model of tractor you like are the challenges. Good luck!
   / Trying to find the right tractor... #7
Take a look at the Mahindra 25 series (4025, 4525, 5525) or the Massey Ferguson 2600 series (2615, 2625).
FIRST thing I would do is set myself a price range.
Second, If you're buying new, I would see what tractor brands are sold 'locally'.
Third, I would ask myself a few questions:
1) Is there anything I might plan on doing with my tractor in the future?
2) Do I need an FEL (front end loader) ?
3) Do I need a 4WD (four wheel drive) tractor ?
**If you buy a tractor with a front end loader, you should definately consider 4WD**
You already have some implements chosen... What size box blade do you want? What size bush hog? What size finishing mower? It all depends on how fast you wanna get done with your yard work.
What kind of fence are you putting up? This determines the size of auger bit you'll initially need for the post hole digger.
Last but NOT least... When you choose the right dealer to go with (if you're buying new), tell him everything that you're planning to do in detail. He'll give you options to choose from.
For 12 acres, I wouldn't buy a tractor under 35 engine horsepower. Personally, I would be looking more into the 40-50 hp range.
You never know what you may wanna do "in the future"...
Thanks for all the advice. I have considered an older tractor. Found a 52 8n for $2400 looks to be in good shape but didn't know if I should consider something that old. I just don't want to be working on something every time I get ready to do something. Then I thought about maybe going newer and taking advantage of some of this 0% financing. I live in Dothan, AL and we pretty much have every type of tractor dealer in this area, but yes money IS an object. I would like to just pay cash for something say under $5000, but I also want it to be reliable and not take on somebody else's headache. I would'nt think I would need more than a 5ft mower and maybe a 10 in auger. So when were talking about hp say a 30. What is the ratio to the shaft or is it pretty much standard no matter what brand you buy? Also if I do get an older tractor do the attachments still fit? Sorry if these questions sound strange nut I am a newbie. Thanks again for yalls help.
   / Trying to find the right tractor... #9
I'd identify what you might want to do with the property first!!! You do have a start but you need to figure out how much time you have to do it first and then you can better look at your needs.
You mentioned a ford 8n, are you aware that when you step on the clutch petal that the PTO stops? The hydraulics stop as well and there is no overriding clutch or system on the pto so it might also drive you through the fence you want to build?
When looking for a brush hog to mow your pasture you should look for a tractor that is also less width then the mower so it looks nice when done! Maybe you don't care but there are a lot of things to look at!
It's always fun to sit at the computer and spend someone elses money!!!!
That's something I haven't thought about. I do want the pasture to look nice and I would like to mow my yard with the same tractor so the width is definitely something to consider. I plan on this just being a place for kids to play and ride a 4 Wheeler. Maybe have a small garden or something but mostly just a place that's well kept. As for the pto stopping when the clutch is engaged is that something I need to avoid?
2022 Kawasaki Mule Pro-DX EPS 1000 (A51573)
2022 Kawasaki Mule...
2020 JOHN DEERE 331G SKID STEER (A51246)
2020 JOHN DEERE...
New/Unused CFG Industrial XZ20R Mini Excavator (A51573)
New/Unused CFG...
UNUSED AGT 3000 PSI HOT WATER PRESSURE (A51248)
UNUSED AGT 3000...
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A52377)
2014 Ford F-450...
PRO WORKS PWFF LOT IDENTIFIER 143 (A53084)
PRO WORKS PWFF LOT...
