trying to figure out what my serial number is
   / trying to figure out what my serial number is #1
blanckmd
Fruitvale CO
Ford ???
I purchased a what was supposed to be a Ford 3000 3 cyl. diesel tractor.
It seemed to be leaking fuel so I (like a fool) decided to "fix" it. I took all the sheet metal off and pulled all the wires loose (thinking wrongly that I would remember how they went). I replaced the gasket on the valve cover and sealed the fuel sender, and tightened the fuel valve. Now I am trying to find a wiring diagram but am having trouble identifying the make and model of my tractor.
Every where I look it says that there is 3 lines to the serial number, I can only find two.
Line one: 7D7
Line two: B 836633*
Just for clarification, the B seems to be just a bit smaller than the numbers and the numbers are followed by a five point star like an asterisk.
   / trying to figure out what my serial number is #2
deffinately 3 lines.. and the hood has a foil tag with dupe info.
post back.
   / trying to figure out what my serial number is #3
post back.
Maybe the original numbers were removed? I sent a photo to someone of the location and the numbers as they appear.
   / trying to figure out what my serial number is #5
you sent them to me so far.. :)
unless you see grinding past the machined area, it is unlikely they were removed. however pas tthat machined area is wher ethe other row likely was.
There are no other marks on the right side, however now that I have gotten some of the paint off of the left side I can make out 2 lines of numbers on that side
Top line: 7C29B
Bottom line: 7008
   / trying to figure out what my serial number is #7
7c29b is a date code. again.. 1967 april 29 b shift. kinda jives with that 7d7 you saw...
the 7008.. is that a raised casting number?
No it is stamped in as are the others.
2017 KENWORTH T800 (INOPERABLE) (A53843)
2017 KENWORTH T800...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
2007 Chevrolet Tahoe 4x4 SUV (A51694)
2007 Chevrolet...
Light Tower (A52377)
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
