Trying out a Brush Grubber
   / Trying out a Brush Grubber #1
nikdfish
Veteran Member
Person Co. NC
John Deere 3038E & 1025R FILB
After running the rotary cutter over all the saplings I dared to drive over, I still have a bunch that were too thick to try that - & a bunch of stumps that have been a pain to try to grub out with box blade scarifiers & FEL bucket.
I thought I'd try a different tack and look into pulling rather than pushing. I had to send back a defective Christmas gift that had been purchased via Amazon. Rather than wait for the same item to come back in-stock, I used the store credit to pick up a BAC Indus. BG-08 brush grubber.
It works as advertised. I hooked one end of the chain to the front of the frame, the other to the grubber. The main thing is getting enough traction. Some of the areas I had been working in have the sod scrapped off & sandy loam makes for spinning wheels! The approach that worked was to use additional length(s) of chain to get the wheels on firm ground. The biggest hassle was constantly dismounting & getting back on the tractor.
I put a short vid on youtube.
Nick
sorry about not providing a close-up in the first post ...
The version they are shipping is a little different from the manuf. web site. The ones being shipped appear to have cast components on the "arms" rather than bar stock.
Nick
   / Trying out a Brush Grubber #4
On Youtube, there are lots of videos of this gizmo:cool:
   / Trying out a Brush Grubber #5
I guess ya know that you will get a lot more traction if you attach your grubber to the drawbar and go forward rather than back up
Probably a good idea, but no drawbar ... haven't put one on yet :eek:
(also not real good at looking back over my shoulder - too many fused vertibrae in my neck :) )
Nick
   / Trying out a Brush Grubber #7
use your boxblade as a drawbar and get a mirror. good luck with the back
   / Trying out a Brush Grubber #8
Would a chain work just as good? I would use the fel to play bull dozer,no
bigger than that was.
The FEL was what I tryed first. It took way too much digging before there was enough leverage to get them out working from the bottom. Way too limber to just push from up higher - they act like a shock absorber & the root just stays put.
The advantage over just the chain is that the grubber clamps on firmly & doesn't slide. Generally the trunk is horizontal for a while before the root even starts to break loose.
Nick
Actually my original intent was to do just that... I ended up hooking up in front cause it was quicker & easier at the time, especially when carrying the chains & grubber around in the bucket between trees. I'll give the rear pull approach a try next time out.
I really do appreciate any & all observations & tips!
Nick
   / Trying out a Brush Grubber #11
If you get a tree bigger than you can handle you will slip going backwards, but you can flip over going forward. Just a word of caution.
Thanks for the reminder. I have the box blade mounted & figured I would be running the chain underneath it. If it is lowered to just above grade (the scarifiers aren't down) my assumption is that it should serve as a safety device in regard to the potential for flip-over.
Nick
   / Trying out a Brush Grubber #13
If you google tree shears, they mount on a fel or 3 piont hitch. they look like
a neet toy then you sell it after you are done. No holes,just spray stumps with brush killer. Let me kwow how they work.
   / Trying out a Brush Grubber #14
Thanks for posting this, I have been considering buying one; looks like a good product.
   / Trying out a Brush Grubber #15
I've used mine a few times and it worked fine.
   / Trying out a Brush Grubber #16
has any one tried a tree shear?they look like they would be the ticket, but they wiegh so much. the big 20'' wiegh 2000 lbs, thats getting close to my limit on a deere 5525.
   / Trying out a Brush Grubber #17
The tree-grabber looks cool and may be faster, but I have pulled dozens of little tree's like that with just wrapping the log chain around them 3 or 4 times and hooking it to itself. It rarely slips, it nearly always bites in and yanks them right out.! Of course you need a "groundman" to keep from getting on and off the tractor all day.
James K0UA
   / Trying out a Brush Grubber #18
Is there not a place to put a tractor hook on the bottom of the rear axle? I use a hook on mine and just put the chain on it -- way easier than a drawbar and as low as possible on the tractor from a safety standpoint. Even pulling from the rear I lose traction when pulling spotted alder:eek:
   / Trying out a Brush Grubber #19
I think you might find it more effective if you attach it low on the tree (at ground level) and route your chain up over a wheel or a post notched on top to give you an up pull instead of a sideways pull on the tree For a wheel, look to get yourself an old wooden cable reel or a large steel car or truck wheel from a junkyard. Or just use a 4 x 4 post with a notch cut in the top to guide the chain.
Watch this vid and see how this small lever grubber does it Same principle.
YouTube - Metal-handled Brush Grubber Demonstration
   / Trying out a Brush Grubber #20
The biggest hassle was constantly dismounting & getting back on the tractor.Nick
Yeah this could be a real drag if you have lots of trees to pull out and no ground helper to connect/disconnect.
That's why it think something like this is a good idea
Tractor Forks, Bucket Forks, Loader Forks
Several people on TBN have built similar tools based on the same concept Do a TBN search for "tree getter" and you'll see many good ones
2003 McCormick XTX 185 XtraSpeed Tractor (A61307)
2003 McCormick XTX...
2014 Chrysler 200 Sedan (A59231)
2014 Chrysler 200...
2020 Nissan Rogue SUV (A59231)
2020 Nissan Rogue...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
2016 Chevrolet Tahoe SUV (A59231)
2016 Chevrolet...
2014 Ford F-250 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-250...
