Try again
   / Try again #1
Pipestone Kid
Bigfork, Mn.
JD 4110HST
I didn't get any response on the JD part of this forum, so I thought I would ask the same question here. "My 4110 has a lever to raise and lower the three point. When new, I could adjust the height of the blade by setting the lever at any point along the travel path of the lever. Now, I have to pull the lever at least halfway up to get the blade to move. ( same going down) Any thoughts?" Or maybe I should ask if anyone knows of any adjustments? Thanks.
Jim
   / Try again #2
There is a valve below the seat of Kubotas that allow you to decrease and stop oil flow to the 3ph. Perhaps you have something similar and it is adjusted to restrict the flow of oil?
   / Try again
Thanks for the reply. Yes, I have a similar control, but all that does is control the speed of the drop. I tried it again, just to be sure. Nada. The blade goes all the way up and down, but once it hits "6" ( the adjustments are numbered 10 to 0) itis all the way down and likewise you have to get between 5 and 6 to start to raise it.
   / Try again #4
The three point lever bolts directly to another link that is "clamped" in place. My first check would be there it has probably slipped into another location on the control shaft
   / Try again
ctiguy, I checked that out, but the shaft that the clamp is on has a flat spot and so does the clamp--can't slip. Also, there doesn't seem to be any other adjustment in the rest of the linkage. Back to square one...........
   / Try again #6
Don't forget the blade is off the ground to start with. Put the lever all the way down and move fwd real slow and it should go all the way down. Then when you move the lever the 3pt well move as soon as you move it. If the grader blade is on the ground ,say at #5 move to #4 and when you move fwd it well drop the blade some.
   / Try again #7
Do you have a draft sense control lever on that model? If so make sure it is at zero.
   / Try again #8
I apologize if my question is stupid - have you by any chance adjusted the top link of your 3 point a lot? If I have the top link on my Kubota as short as possible, the 3 point will go all the way to the bottom and the blade won't touch the ground. If I have the top link adjusted all the way out, the blade will be on the ground when my control lever is about mid-range and will not begin to raise until I reach 5 to 6 out of a 0 to 10 range. Just a thought of what duplicates what you are seeing when I think about my tractor.
   / Try again
Lejohn--the blade hits the ground at 5-anymovement of the lever after that does nothing
Mistyridge--no draft control
MharryE--you may have hit on something. I will try playing with the top arm tomorrow. It is quite long now.
   / Try again #10
I recommend you take the implement off the tractor and adjust the linkage for a full range of motion. Mine is doing the same thing lately and I need to do this myself before the next use grading. I think it is a linkage adjustment issue, pretty common too.
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
2006 Hummer H3 4x4 SUV (A51694)
2006 Hummer H3 4x4...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
(3) FLOOR JACKS (A53843)
(3) FLOOR JACKS...
