Truck tire tread for plow edge
   / Truck tire tread for plow edge #2
that looks like a lot of work .what is the life of one ....it mite have said but never read it all
   / Truck tire tread for plow edge #3
I did this in late 2008 - see post #21:
http://www.tractorbynet.com/forums/attachments/133717-edge-rear-blade-3.html?highlight=rear+blade
Works great. Still using the same piece of tread with lots of life left.
Omly problem I've had is that the blade will hop/judder on the bare asphalt if set with no angle (bulldozer style). My blade only weighs 340#. I think if I could add 100# to the back end of the frame it would set itself down steady and just wipe the asphalt like it does when angled.
I take it off if I need to use the blade for moving soil.
   / Truck tire tread for plow edge #4
I wore out the plastic wear bar on my Warn plow on my ATV and cut a strip off of a 3/4" horse stall mat. I did the same thing with the drilling and mounting. It does vibrate on dry asphalt but on wet snowy surfaces, it seems fine. I put the metal wear bar between the plow and the rubber strip and put the bolts in from behind. I used fender washers and nylock nuts with an impact driver. Now I can flip it if it wears out one side. The mats are $40 and I can get a bunch of strips out of it. I got my first strip from my neighbor who did it on his tractor, but I guess if it works out, I'll be buying my own mat at TSC. It cuts with a carpet knife. It just takes about 10 swipes to get all the way through.
   / Truck tire tread for plow edge #5
great ideas guys, thanks. I have a 35x75ft truck garage and my truck and trailer goes in it every night(I haul milk for a living). I keep the garage heated, lowest 40f. Warmer if I'm in there working.But this creates quite a mess when the truck thaws out. I've been trying to find a "squeegee" to hook to my bucket of my FEL. Scraping the blade on the cement is not desired, neither is cleaning floor by hand. Since i have multiple old truck tires, I'll fashion one to hook to my bucket. May just drill a few holes in the bucket, get an old cutting edge from my local plow guy. Not too excited about drilling holes into the cutting edge of bucket, but if i did just 3 holes thru the bucket, then weld 4 or 5 extra studs onto cutting edge(the one i get from the plow guy) to help clamp/hold tire in place. Plus it'll be easier on my pavement backdragging by the house.
Thanks for the thread, using the internet for good......tractor ****.
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
2006 S&H HORSE TRAILER (A52472)
2006 S&H HORSE...
