Truck Tag rating
   / Truck Tag rating #1
TailDragon
Oak Ridge, TN
Massey-Ferguson 1652 Cab
How many people have regular tags on their one ton trucks ? Here in Tennessee the regular tag is only good for 9000 pounds. My 2000 F350 4x4 SRW is rated at 9900 pounds. I ended up getting farm tags for 26000 because of the 12000 rated trailer I have. The next lower rating was 20000.
I did not want to go commercial which was the only other option.
I do have farm property in another state (KY) with in the mileage restriction.
   / Truck Tag rating #2
I have a 2500HD rated at 9500 lbs. I run regular tags at $24.00 per year. Never been questioned as to the Over 9000 lb. cutoff. Same state as you.
   / Truck Tag rating #3
In NC, the regular tags, $28, have a weight limit of 4000, grace up to 5000, but if you pull a trailer it's 9000. Depends on how busy local DMV enforcement is whether you get pulled. If you have anything in the bed you could be overweight, just goes in cycles if they are actually looking. I have farm tags, 99 F250 SD 4x4, 16,000lbs tags, $111 I think. Never been pulled for weight, know some who have.
   / Truck Tag rating #4
When i had my Dodge/Cummins I ran regular car/passenger vehicle tags at 7500 lbs (max for a passenger vehicle).. They were more expensive than a 'truck' tag, BUT sorta saved headaches with towing trailers if i would have been stopped - If i would have been stopped they would have had to weigh the truck and trailer separately, not as a single unit.
Around here the weigh stations like to catch 1 ton duallys running the same passenger car tag when the empty weight of the truck is greater than the gross on the tag. Easy money
brian
   / Truck Tag rating #5
I don't understand why you guys are putting huge tags on trucks in order to include the weight of towed trailers. That is not needed in my state AFAIK. My Suburban, for example, has a 7000# tag which is common (really should be 9000# but the BMV cuts 1/2 ton owners a lot of slack) and the truck curb weight is around 5500#. I tow a 10K GVW trailer with it routinely, that has a 9000# trailer tag on it, and I think with the equipment in it right now, the trailer's actual weight is about 6000# to 6500#. If I had to add truck+passengers+cargo+trailer it would be 12K but obviously I don't need 12K tags on a 1/2 ton Suburban.
   / Truck Tag rating #6
My 06 F-350 SRW 4x4 Diesel has 11,500# GVWR package and I run regular truck plates. The run around $300 per year. I run the same plate type on my 08 Nissan Titan 4x4 with 6,522# GVWR.
Chris
   / Truck Tag rating
The reasons I run the higher rated tags is to cover myself. I still have a CDL with X endorsement which I use on my part time job if I have to transport hazmat. In Tennessee the semi tags on my trailer do not have a weight rating. Semi tags because the trailer is 102 inches wide, one time payment.
What I could find on line indicated prime mover had to be tagged to meet the combined rated weights, not just what you haul.
Count clerk's office indicated the same when I renewed tags.
Did not know other states had lower limits on regular tags.
   / Truck Tag rating #8
In NC and many other states, our truck tags carry the weight, the trailer tag is $19/year or $75 multiyear, but not all trailers have to be tagged. Trailer tags are for registration, no weight attached.
   / Truck Tag rating #9
Here in Indiana we buy trailer tags for the GVWR of the trailer. We have 3,000#,5,000#, 7,000#, 9,000#, 12,000#, 15,000#, ect.
Chris
   / Truck Tag rating #10
Speaking of, I put a 9000# tag on my 10K trailer because I did not want to attract attention with anything bigger. In the event I actually got weighed and was over 9000 but still under 10K do you think I would catch a fine? Just curious. The BMV clerk said I couldn't have a larger tag even if I wanted one, but I am pretty sure she was not very familiar with trailer rules.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
Tailgate For Pickup Truck (A53117)
Tailgate For...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
PALLET OF OIL COOLERS (A53843)
PALLET OF OIL...
