Truck question
   / Truck question #1
Chuck52
Veteran Member
Mid-Missouri
Kubota L210
I've got a '91 F150 with the big six engine. Can someone tell me how to adjust the #%^ switch on the clutch so that I don't have to put my foot entirely through the floorboard to start the engine? I have a Chilton's manual which I think would be a fine sustitute for the old Sears catalog in the outhouse. By contorting myself upside down in the floor of the truck, I can see what I think may be the switch. At least there's a device on the clutch shaft with wires coming from it. Naturally, the wires are in one of those clips with retaining ears, only one of which is accessible, so I can't easily disconnect the wires without breaking it. Who designs these things?/w3tcompact/icons/mad.gif
My next rant will be about how I just paid the shop $71 to replace a burned out wire up under the dash of my Caravan that they should have found when they replaced the headlight switch which probably caused it to over heat, for which they charged me about $150! AAAAARRRRRRGGGGGGHHHHHH!!! If I can get to it, I can usually fix just about anything. So I guess that's the idea....make whatever is likely to break so hard to get to that you'll give up and just pay them to fix it. /w3tcompact/icons/mad.gif/w3tcompact/icons/mad.gif/w3tcompact/icons/mad.gif
Chuck
   / Truck question #2
But if they itemized the bill it would say:
Replaced wire= $5.00
Knowing which wire to replace $66.00
/w3tcompact/icons/smile.gif
Those things are designed for quick assembly, not disassembly/w3tcompact/icons/sad.gif
find the hot wire and jump it to the wire that starts your truck.
   / Truck question #3
Chuck:
All Vehicle design engineers should have to do repair work on the designs they have created. And it should be done in -20 F weather with a strong north wind blowing and no HOT COFFEE at hand. Then maybe, just maybe they could come up with a workable design. The Managers of the design team should also have to do the same repairs but at -40F temperatures with bare hands and no rerspite till its running.
Egon
   / Truck question #4
Chuck:
Forgot to add:
All menbers of the board of directors and the three major stockholders of the company should have to sit in the vehicle wearing swim suits till the CEO can fix the problem at -50F with a strong north wind blowing.
Egon
   / Truck question
Egon, on re-reading my post I find that I have succumbed to the very thought pattern I have chided others for. I must keep repeating, "Assign not to malice that which can be adequately explained by ignorance." I'm sure the designers and their bosses aren't deliberately trying to cause me pain. They are simply ignoranuses. (spelled correctly) /w3tcompact/icons/smile.gif
Chuck
   / Truck question #6
Chuck,
Are you calling them Anuses? tsk-tsk.... /w3tcompact/icons/wink.gif
Terry
   / Truck question #7
<font color=blue>Those things are designed for quick assembly, not disassembly</font color=blue>
A lot of truth to that, although there is increasing effort put into servicibility and recyclability (including disassembly). The other thing to remember is a '91 truck is nearly 15 model years old in design and many of the components may be much older.
I'm not saying it's right, just felt the need to defend my industry a bit. Kind of a micro-patriotic thing /w3tcompact/icons/smile.gif
   / Truck question #8
I wish the government would stop making us cram the interior with safety devices and features which crowd in the occupants, kills babies in car seats, adds weight which we have to take away from other areas like STEEL panel thickness just so we can stay within CAFE standards.... Oh wait a second all that just spells job security/w3tcompact/icons/shocked.gif.
   / Truck question #9
Thats true also, that connector was probably first used on an Edsel/w3tcompact/icons/crazy.gif
By using that off the shelf item, Ford saved enough money to hire another line worker so the first one didnt have bend their waste more that 10 degrees while installing the IP.
   / Truck question
Geez. Eight answers and not a one any more useful than my offer to help someone on another discussion grow a third arm so he wouldn't have to buy a cordless grease gun.
Chuck
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
2016 GMC SIERRA 3500 SERVICE TRUCK (A51406)
2016 GMC SIERRA...
Lockwood 480 Pecan Harvester (A53473)
Lockwood 480 Pecan...
2018 Infiniti QX60 AWD SUV (A51694)
2018 Infiniti QX60...
